DK45 with DK50 turbo
   / DK45 with DK50 turbo #1
intel
Fairmont, West Virginia
DK 45, 2003
has anyone ever taken the turbo from a DK50 and put on a DK45?
I have an opportunity to buy a newly rebuilt turbo from a DK50 for $800.
The only other thing i would need for my DK45 is the oil feed line and return line and muffler and gaskets.
But i notice the timing is different from a DK45 to a DK50 12 degrees versus 18 degrees i believe. would timing have to be changed?
   / DK45 with DK50 turbo #2
Yes,
the fuel pump may need to be changed to.
   / DK45 with DK50 turbo #3
Intel, look at a DK55 specs Its basicly a DK45 engine with a turbo. you will also need different manifolds and the turbo will create a little more heat. I know my DK50 never runs out of power. good luck if you try it. FRENCHIE
   / DK45 with DK50 turbo #5
just thinking that seems like a lot of $$ and time for 5 hp???
   / DK45 with DK50 turbo #6
Would hate to mess up a perfectly well running tractor. How often do you actually stall out your tractor for lack of power. If in the correct gear, very difficult to run out of power with a tractor your size.
My little LK3054 will spin in 4x4 under almost any load.
Joel
your right a lot of work for 5 hp. i have no problem with power only stalled once in 80 hours digging hard dirt.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2016 GENIE TZ-34/20 ELECTRIC TOWABLE BOOM MANLIFT (A51247)
2016 GENIE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
