DK45 FEL capacity issues?
   / DK45 FEL capacity issues? #71
The relief valve is in the FEL control valve by the inlet pipe. It has an adjustment screw with a jam nut. Loosen the jam and turn screw in to increase pressure. Turn it about 1/4 turn at a time then retest pressure until you get correct setting.
What did that testing rig cost you altogether?
I have a lot more in it than necessary as I jumped the gun and ordered the wrong fittings the first time around and would purchase a few other things differently. Plus I had to pay relatively expensive shipping multiple times. It could also be built less expensively if only used as a dead head device. But I wanted to build one that could be used as dead head or operational pass through, to cover all bases. And also the reason I ordered couplings for all types on my tractor.
The only design change I would make is to use a gauge with a back mount fitting instead of the bottom mount. This would allow use of a 90 degree swivel that seems to swivel independently in place when installed. I am currently using a straight swivel from Northern Tool who's position can only be adjusted by loosening the fitting- moving the swivel and then re-tightening.
Pricing listed below is what I could build another one for with my new found experience level. Most of the items came from Discount Hydraulic hose, except the hoses which were from Amazon.
Basic pricing now I have built one and know what fittings to use:
36" Abbott 1/4" 5800 PSI hose: $17.10 (4000 PSI versions are less expensive at many places)
Bottom mount 5000 PSI gauge: liquid filled: $17.31
3/8" T fitting: $7.90
Each pair of ISO hydraulic couplings: ~$17 - $20 (ISO 16028 coupling pairs are more like $75)
Swivel fitting: $13.30
Misc. fittings, adapters, etc: $35 - $50
Shipping: $15.00+
Nice Rig, where did you buy it?
Made it. Posted price info on a different post. When I put this together, I decided to use Permatex hydraulic pipe dope instead of the yellow Teflon-type tape I usually use, as quite a few knowledgeable folks in TBN hydraulics recommend dope/liquid vs. tape, although it was not this particular brand. I have never had any problems using Teflon tape. I had nothing but trouble with this pipe dope and small leaks- nothing that would effect pressure readings though, and now have to take it all apart and reinstall with tape. Grrrr....
   / DK45 FEL capacity issues? #75
Shipping: $15.00+
Thanks. That is very helpful.
Thanks Dennis. I will look around there. But there is not much room to view or adjust if it is located anywhere other than on the bottom of the FEL control valve.
   / DK45 FEL capacity issues? #77
It's on back side/rear of the valve. Easy access.
   / DK45 FEL capacity issues? #79
Perfect. Thanks.
Greg
while you're down there making that adjustment take a look at the metallic pipe coming into the banjo bolt into the side of the valve. This summer I have that bolt loosen up and I lost a couple gallons of fluid in a couple seconds that's the feed coming from the pump check it out And put a wrench on it.
James K0UA
   / DK45 FEL capacity issues? #80
I am not bragging or anything about being a superior operator. (Ok maybe I am) but I pay attention to how the tractor is reacting and modulate the HST pedal to not load the engine down. I push in to the pile and let off of the pedal,
What he said. Question how much increasing the presure by 100 psi will help.
I've stalled mine a couple of times but technique is something learned.
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2010 FORD F-150 (A58214)
2010 FORD F-150...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
Club Car Electric Utility Cart (A55853)
Club Car Electric...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
