DK4210SE wiring for work lights
   / DK4210SE wiring for work lights #1
Matco Steve
Ontario, Canada
Kioti DK4210SE
Does anyone have a wiring diagram for a DK4210SE or any of the DKxx10SE series tractors?
Trying to wire up some work lights and found wires at the back of the tractor that go to a plug in the steering column. The factory switch is $45 so I am just going to install an aftermarket switch but there are 4 wires for the factory plug.
One wire is ground and another is switched power. The last two wires both seam to control the relay in the fuse panel.
   / DK4210SE wiring for work lights #2
How did it work out? Any luck?
   / DK4210SE wiring for work lights #3
I'm starting to think about this same task, DK4210SE, no cab. I see in the service manual there is a 20AMP line labeled "Working Lamp". I think this is used on the cab models for the working lights on the cab. I was wondering if I could tap into that.
As Eco88 said, how did it work out, can you share anything you learned? Eco88, did you get some lights wired up?
   / DK4210SE wiring for work lights #4
I’ve got a DK5310SE I just bought and wanted to transfer over my ROPS mounted light bar from my old tractor. Haven’t gotten to it yet. I think there’s wires on both left and right sides in back. My setup uses a surface mounted switch to control that’ll I’ll mount to the rops with double sided automotive tape. I was going to get out the multimeter and check first when they’re energized (ie key on or running, all the time, etc).
   / DK4210SE wiring for work lights #5
Starting to look at this project.
Found "Working Lamp (F)" wires on the rear right. Meter found no voltage, not even when engine running, lights on. Missing fuse? relay?
Looking at the fuse box, looks like I need a relay. Just a dummy plug in there now.
Not sure what relay to buy, seems it should match the one in the head lamp, but not sure.
   / DK4210SE wiring for work lights #6
Seems I'll need a switch too, OEM switch, $60... I think I'll buy a third party switch.
   / DK4210SE wiring for work lights #7
Okay that would make sense. Likely powered when key on. And yes then switch to control lights. It’s probably the same relays as others in there. Depending on the pin style you might be able to use just a generic automotive relay.
   / DK4210SE wiring for work lights #8
Yeah, I guess the drawback when using the existing built in working lamp circuit is the wiring to the switch would have to be to the one and only switch under the steering wheel. I was planning on two switches, one for front working lights and one for back. I'm considering using something like a "2-Circuit Led Light Bar Wiring Harness with it's own fuse and relay" instead and using the blank plates to the right and behind the seat for the switches. I think with those pre-built circuits people generally connect to the battery or starter directly.
   / DK4210SE wiring for work lights #9
So I have this working, was able to test it out last night, so much more light!
Front Light - YITAMOTOR LED Light Bar 14inch 72W Led Work Light Spot Flood Combo Led
Rear Light(s) - Nilight - 60001F-B Led Pods 2PCS 18W 1260LM Flood Led
Switches - Nilight Rear Lights Rocker Switch Led Rear Light, Nilight Rear Lights Rocker Switch Led Light Bar
Relay - MICTUNING Heavy Duty 14AWG 300W 2-Circuit Led Light Bar Wiring Harness Kit with Fuse - I ended up not using too much of this other than the relay and the wiring to the switches.
Wire - Geosiry Electrical Wire - 30Ft 14AWG
Wire protection - Electriduct 3/8" Split Nylon Wire Loom Tubing
I had some square U-bolts and flat steel I used to make a mount for the lights. As I said in the last post, I ended up running a wire from the starter to the relay and switches which I mounted on the and under the right console next to (and behind) the seat.
   / DK4210SE wiring for work lights #10
It will be easier if you provide me with an illustration.
   / DK4210SE wiring for work lights #11
Hi Folks,
I finally got around to moving my light bar over from my old tractor to my new DK5310SE. I've got the repair manual so I spent some time studying the diagrams etc.
There's two options to wire in lights:
Rear Light Circuit
  • There is a set of green and black wires tucked up on the far right and far left at the back of the tractor labeled "work lamps".
  • These are referred to in the manual as Rear Working Lamp L & R. You'll need a 5 pin relay added to your fuse box per the earlier photos. I didn't confirm but you'll probably need a switch.
  • See photos on the relay you'll need, but any 5 pin should work. I'd just match the 14V rating and get one rated 40A normally open, and 30A normally closed which matches the Kioti version. The Kioti version is ~$25 on Ebay from some of the Kioti dealers with an Ebay store.
Front Light Circuit
  • This is what I did.
  • There is a set of red/blue and black wires tucked up in the center at the back of the tractor. No label on these, but per the manual they're referred to as Front Working Lamp.
  • You do not need a relay for these. They are energized with key on.
  • My light bar is mounted on the ROPs, so I ran the wiring up the inside of the ROPS with cable ties.
  • I added a switch on the wire run up ROPS bar. It's not mounted to the ROPS, just lies against the bar with cable ties. I didn't want to drill the dash or anything. Search for inline switch if interested. I found a wire harness meant for a 12V sprayer tank, and just cut the end connectors and spliced it in between my light and these wires on the back of the Kioti.
This should be pretty easy for folks, hope this is helpful. I sure appreciated not having to run wires all the way to the battery, thanks Kioti!
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
Rhino DB150 (A57148)
PALLET OF 45" BAR LOCKS (A60432)
PALLET OF 45" BAR...
