Dk40se
/ Dk40se #21
If the dealer can provide a record of having done the 50 hr service, on paper with the hours evident, then you're all set.
I believe the OEM factory hydrostat filter is grey or black and the replacement ones are a yellowish color. That would be easier to verify, especially if you check a brand new tractor on the lot, instead of wrestling with the filter to see if it removes easily.:confused3:
My original Hydrostat filter was also the same Ocher/yellow color as the replacement. The horizontal high pressure hydrostat filter on the left side was easy to remove. The vertical hydraulic filter on the right side is the one that is tough to remove. I am not suggesting that you should try to remove the filter to determine if the 50 hour was done or not, as when you try to remove the filter, you will likely damage it. My point is that it will be very difficult to determine if the 50 hour was done or not, unless someone kept records of it.
/ Dk40se
Brought the thing home . Man it is a beast to me anyways thanks for all the info . Guess I will go to other questions now since I done buying
/ Dk40se #23
Well it ain't so till we have some pictures.;)
/ Dk40se #25
Lol I will try to figure it out and post one
Congratulations, it is a great tractor and you will love having it. Yes it is a beast, just go slow and keep that bucket down when it is loaded. Read that manual from one end to the other, and come back here for any questions you have, no matter if you think they are trivial or not. But you will soon be operating it like a pro. Good luck, and we are looking forward to seeing it.
/ Dk40se
Thanks I put a topic in kioti operating but can't find it , at least I thought I did maybe I'm blind ... I will get a pic tomorrow if I'm home .................. Guess I'm blind see it now
/ Dk40se #27
Congrats!
/ Dk40se
/ Dk40se #30
Nice looking rig!.. real "sticky" tires too!:D
Titan must have changed something about the rubber compound. Mine wont do that! :eek:
2006 GMC C5500 4X2 BUCKET TRUCK (A59906)
2006 GMC C5500 4X2...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
Westerbeke 6EKOD-CP1 6kW Marine Generator (A59231)
Westerbeke...
Kubota SVL75-2 (A60462)
Kubota SVL75-2...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2006 TerraGator 8104 (A61307)
2006 TerraGator...
