Dk40se
/ Dk40se #21
If the dealer can provide a record of having done the 50 hr service, on paper with the hours evident, then you're all set.
I believe the OEM factory hydrostat filter is grey or black and the replacement ones are a yellowish color. That would be easier to verify, especially if you check a brand new tractor on the lot, instead of wrestling with the filter to see if it removes easily.:confused3:
My original Hydrostat filter was also the same Ocher/yellow color as the replacement. The horizontal high pressure hydrostat filter on the left side was easy to remove. The vertical hydraulic filter on the right side is the one that is tough to remove. I am not suggesting that you should try to remove the filter to determine if the 50 hour was done or not, as when you try to remove the filter, you will likely damage it. My point is that it will be very difficult to determine if the 50 hour was done or not, unless someone kept records of it.
/ Dk40se
Brought the thing home . Man it is a beast to me anyways thanks for all the info . Guess I will go to other questions now since I done buying
/ Dk40se #23
Well it ain't so till we have some pictures.;)
/ Dk40se #25
Lol I will try to figure it out and post one
Congratulations, it is a great tractor and you will love having it. Yes it is a beast, just go slow and keep that bucket down when it is loaded. Read that manual from one end to the other, and come back here for any questions you have, no matter if you think they are trivial or not. But you will soon be operating it like a pro. Good luck, and we are looking forward to seeing it.
/ Dk40se
Thanks I put a topic in kioti operating but can't find it , at least I thought I did maybe I'm blind ... I will get a pic tomorrow if I'm home .................. Guess I'm blind see it now
/ Dk40se #27
Congrats!
/ Dk40se
/ Dk40se #30
Nice looking rig!.. real "sticky" tires too!:D
Titan must have changed something about the rubber compound. Mine wont do that! :eek:
/ Dk40se #32
Hey, you guys never told me the DK had an anti-gravity setting:laughing:
/ Dk40se #36
LOL Yea sorry bout that will try to get one right
Nice set-up. Congratulations!
The photo rotation by 180 degrees, rather than 90, is a new one on me. The few jpgs I've posted recently show up fine in the embedded thumbnails in the posts, but when double-clicked to enlarge they rotate 90 degrees clockwise. So I have to upload them again after first compensating by editing them 90 degrees counter-clockwise. Or maybe there's another trick I haven't learned on TBN. :confused3:
STEPP SEALCOATING MACHINE (A59914)
STEPP SEALCOATING...
2022 Bobcat MT100 (A64126)
2022 Bobcat MT100...
KL480 Ventrac tiller
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
(6) 250 Gallon Chemical Totes (A64127)
(6) 250 Gallon...
