DK40SE Shuttle problem
/ DK40SE Shuttle problem #11
The transmission is the heart (and chassis and frame) of a tractor. The older utility tractors (like a Ford 8N or Massey 135) shift like a car: one shift lever with one reverse speed and several forward speeds. Soon, gear ranges (H-M-L) were added for better forward speed control while running at PTO speed. When most tractors started using loaders, the shuttle came into style, and it was a great improvement. Power or hydraulic shuttles (no clutching required) were the next step but hydrostatic transmissions came soon and most folks like them even better than the power shuttle. Now, I think a straight gear setup (like the OP) or hydrostatic are most popular. The gear setup is an efficient, mature design but abuse can wear the clutch prematurely, a costly repair. Utility tractor hydrostatics are less mature but less vulnerable to operator abuse and work great for frequent direction change.
The DK 40se is not a hydraulic shuttle and requires using the clutch to shift and to forward/reverse.
Hydraulic shuttles can be shifted forward/reverse without using the clutch.
Use the clutch on the DK 40 or transmission damage is likely.
Yeah, I've had the tractor since new and I've always used the clutch. I have no problems with the trans. My friend was trying to convince me that it would shift without the clutch, so I tried it and it wouldn't and I didn't think it would....but I had to find out. So, I've learned something he don't know and it is that he has a hydraulic shuttle....and I don't.
/ DK40SE Shuttle problem #13
Ya gotta be smarter than the tractor.
/ DK40SE Shuttle problem #16
I've been tryin to tell ya for years Murph.......
One of these days I will learn. But not today I guess. Happy Easter my friend.
/ DK40SE Shuttle problem #17
Happy Easter to you Murph. One of these days I'm gonna show up in Ohio.
BOX BLADE (A58214)
BOX BLADE (A58214)
CFG Industry 680 QA Hydraulic Breaker (A60463)
CFG Industry 680...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
Toro z turn (A56859)
