DK40 front bearing failure @ 1300 hours
   / DK40 front bearing failure @ 1300 hours #91
That looks like a portal, so easily serviced. Pop the bolts out of the top, use one bolt as a jack bolt to pop the top cover off, and you'll be looking at the bevel gears and bevel shaft.
I don't think I'd bother replacing the gears unless there is a real chunk missing. Too bad about the backside of the portal housing has a chunk missing where it looks like to my eye the bevel gear grabbed a loose bearing and took it for a ride.
   / DK40 front bearing failure @ 1300 hours #92
I dread changing that 140 weight gear oil in there
I’m Not sure why. Remove plugs and let drain while having coffee, or a beer with lunch. Replace plugs and refill with gear lube.
Oh….it’s not free though 🥴
It is not the draining, it is the filling that is tedious. Even 90W gear oil takes a while since the fill hole is not large. I will not use 140 again cuz it takes so long.
   / DK40 front bearing failure @ 1300 hours #93
Gotcha. Why not use a 75-140? Covers a wider range of temperatures too…
   / DK40 front bearing failure @ 1300 hours #95
Use a synthetic then….but not cheap for sure
   / DK40 front bearing failure @ 1300 hours #96
That stuff is very thick at room temp, and my axles take a LOT.
Over a 1,000 hrs. on my tractor with trans hydraulic in the front end with O problems so far. Replaced many seal and bearings in the past with gear oil so thought it wouldn't hurt yo give it a try. It works good in the planitary's on my backhoe and excavator so why not my tractors front end.
Replaced a coil on the zero turn today then mowed.
Might look at the DK tomorrow & if the bearings are ok, maybe a flush and replace axle seal is only needed. Will update soon.......
   / DK40 front bearing failure @ 1300 hours #98
I run tractor fluid in the front diff of my 2002 DK40 (as OEM)and I'm surprised that I didn't suffer the same fate as motorseven. I don't know how many trips I made hauling full loads of creek shale up a 90' gorge on a 30-40 degree incline. Only part I ever needed was a tach cable $7.00......love this tractor.
Well, the inner bearings are ok, outer is trashed. Now I will have to pull the LF too, check the bearings there and flush everything. Headed to a bearing place today to see if they can match them(OEM bearing is $54.34ea). The OEM oil seals (floating seal assembly) list for $85.87(one side).......both rings on the RF are intact, so I think I am going to just find some O-rings that size.
Maybe the issue is slightly damaged hubs, or maybe it needs a bevel gear adjustment? Looking at the manual, a bevel gear adjustment is a bit intimidating. All I know for sure that something 'aint right'.
_No go at the bearing place, close but no banana.
2015 Ram 3500 Crew Cab Truck (A52384)
2015 Ram 3500 Crew...
KMC KELLEY 3360 PEANUT COMBINE (A51247)
KMC KELLEY 3360...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
UNUSED HURRICANE G350 MINI CONCRETE MIXER (A51248)
UNUSED HURRICANE...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
