DK40 front bearing failure @ 1300 hours
   / DK40 front bearing failure @ 1300 hours #81
At about 1000 hrs. on my DK40, I'd like to inspect/ possibly replace my front wheel bearings and seals.
Any good advice or pictorials?
   / DK40 front bearing failure @ 1300 hours #82
Why, Just put the bucket down to lift up the front end and check the wheels to see if they are loose. Spin them to make sure they feel smooth when turning. I just turned 1200 hours on my NX4510 and the front end feels fine. My loader gets used a lot.
   / DK40 front bearing failure @ 1300 hours #83
I spoke too soon about my tractor. Now at 1259 hours on my NX4510HST I have a front wheel seeping oil slightly. The hub is tight. Looks like I will be doing the wheel seal and both bearings while it is apart. Probably a good idea to do both sides.
   / DK40 front bearing failure @ 1300 hours #84
easy check on oil change pull
Plug silver oil you got issues
My weed abatement guy puts 500 miles on his kubotas every year Put in synthetic oil and lost me a lot of money
But he is happier
I'm baaaaack...right side axle seal leaking again....yay!
Starting to think the axle tube is damaged, this is getting old. I am not lifting anything but hay & always in 2wd.
   / DK40 front bearing failure @ 1300 hours #87
Ouch! The older I get, the less I enjoy equipment problems.
Your dealer did the work last time, correct? Outside of my local mower shop, I've had nothing but disappointment in equipment and vehicle service providers. Due to my distrust of Hyundai service department(s), I'll soon be rebooting a CV joint on my still under warranty car. It is so difficult to find good service.
Please keep us updated and take lots of pictures, as I'll be doing this repair as preventative maintenance once my tractor hits 1000 hours.
Good luck!
   / DK40 front bearing failure @ 1300 hours #88
Old thread, but very important. I am going to lift and inspect my front hubs to see if they spin freely with no noise or wobble. At nearing 1100 hours, and soon to be 20yo, my Kioti has been great. I have lifted and moved hundreds of logs, sometimes only an inch or so off the ground, at the very limits on my capacity. I dread changing that 140 weight gear oil in there.
Since I bought my first car in the 70s, I have always done all my own repairs. Recently bought a Hyundai Ioniq HEV that had "free" maintenance for 3 years. I took it in for a software update (not free!), and they told me an oil change would be 2-3 hours. I left.
   / DK40 front bearing failure @ 1300 hours #89
mine is still tight and leak free since the repair...knock on wood.
   / DK40 front bearing failure @ 1300 hours #90
I’m Not sure why. Remove plugs and let drain while having coffee, or a beer with lunch. Replace plugs and refill with gear lube.
Oh….it’s not free though 🥴
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
7021 (A50322)
7021 (A50322)
