DK40 cranking but not starting
   / DK40 cranking but not starting
At last found a site which shows a much closer resemblence to my engine (although this is a 3-cyl engine), and actually shows how to disassemble the solenoid and IP. Looks like fun ahead...
IP Removal
   / DK40 cranking but not starting #42
Curious what the outcome was here. I have a similar problem on a DK45S cranking but not starting or starting sometimes. Especially hard starting when cold.
   / DK40 cranking but not starting #43
i had the issue on my DK45 years ago. it was the stop solenoid failure. i removed solenoid and manually opened rails. engine fired right up. be careful, as you need to manually shut the tractor off the same way. i had to reinsert stop solonoid to shut down tractor. you could also shut off fuel supply. this was just to try and determine cause. there are 2 relays that control this stop unit. they coiuld also be starting to fail.
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
Informational Lot - Shipping (A57024)
Informational Lot...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE MINI...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A55851)
Dvorak Model 3072A...
UNUSED FUTURE D5T 35" HYD TILT EXCAVATOR BUCKET (A57193)
UNUSED FUTURE D5T...
