dk40 clunks when 4wd is engaged
/ dk40 clunks when 4wd is engaged #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
My Kioti DK 40 clunks when four-wheel-drive is either engaged or disengaged. It seems to me that the noise is getting louder.
Is there anything I should be looking for or at to prevent an expensive fix?
What causes the clunk when the front axle is activated?
/ dk40 clunks when 4wd is engaged #3
Don’t know the answer, but on my MF1540 the 4wd mechanism at the front axle has a zerk in it that I keep greased, so maybe just make sure that yours is greased if you have a zerk. They can be hard to spot; sometimes have to feel around for them.
/ dk40 clunks when 4wd is engaged #4
I would start by raising the front end and turning each wheel by hand to see if I could isolate where it is coming from. If you are not mechanically inclined take it somewhere to be worked on. I would not drive it till it is fixed. Likely a gear or bearing creating the sound.
Maybe check wheel lug nuts are tight first. Could be that is what you are hearing.
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
2019 CIMC 40ft. 36 Ton T/A Container Trailer (A64556)
2019 CIMC 40ft. 36...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A64556)
2010 Workhorse...
