DK40 50 hr service
   / DK40 50 hr service #31
I think a total fluid change is a good idea at 50. When I changed it again around 4-500 it was clear as it could be, so I am not convinced it is needed then. Almost at 1K & I am debating whether or not to change it or just the filters....but I will probably cave and do it anyway.
On a positive note I am converting the wood stove in the shop to burn used motor/hyd oil...so it is no longer going to be wasted.
   / DK40 50 hr service #32
I apologize for the 59th thread on this topic, but I did read a bunch of the previous ones and did not seem to fnid a definative answer. Thanks in advance for bearing with me.
My Dk40 w/ KL401 and KB2875 is at 48 hours, and my inlaws are coming this weekend (meaning I'll be outside or in the shop all weekend), so I'm going to get my 50 hour service out of the way. I have two questions:
1 - Did you guys replace your hydraulic fluid, or just the filter and top off the fluid?
2 - My manual says that the system holds 11 gallons of fluid. When you replaced your hydro fluid, did you find that you needed 11 gallons to get it back to full, or was it less?
I did the fluid and filters, It took 11 gallons, draining the finals as well.
I'm glad I did both fluid and filters.
In the large tub, you could stir the oil with your finger and see the metalic crap, kind of like a metalic paint would look if stirred, no way I would want that stuff in there for 400 hours.
Got it all done this weekend - changed the engine oil/filter, replaced the front axle fluid with 80/90w gear oil, changed out the hydraulid fluid with Traveller Premium UTF, replaced the fuel filter and bled the system, another trip around with the grease gun, and torqued every bolt I could find. All told, probably took around 5 hours - most of which was waiting for the front axle and hydro system to fill. On top of being slow-flowing, the funnel I used had a built-in filter, so there was a whole lot of standing around, sipping coffee, and waiting on the funnel to drain.
I didn't run into any of the filter removal problems that other report. All four of them came off with my old-standby Rigid strap wrench.
In the end, I found another grease zerk I didn't know about (better late than never, I guess), and a failed lock washer on one of bolts on the front backhoe subframe receiver. Glad I took the time to do it myself. I can't imagine paying someone else to do the job - at least i hope no one does it out of intimidation of the process. It really was easy, and I know my machine a little better now.
   / DK40 50 hr service #34
I'm not sure about the DK40SE hst front diff but when filling my CK30hst, it's a two step process. Fill it to what is full, drive it around for about 50 yds. and then recheck. It's always low then and have to top off. Rotating the gears at the ends must take the fluid to places it won't normally flow to. Others with a 40 can tell you if it's the same as the 30.
I think that is SOP when changing any circulating fluid. The initial dipstick (or sight glass, in this case) level always reads high right after the refill. It is not until you've circulated the system, that you find out where the level actually ended up.
Same is true even with an engine oil change in a car. I always run it a few minutes, see where it ended up, and add back tot he level I want to be at.
   / DK40 50 hr service #36
Rcheck all the Fluids after a warm up.
   / DK40 50 hr service #37
I do agree with the total fluid change at 50 hours. Mine had all kinds of crap [shavings ect] in it. I just did my filters at 350 hours and will do a change at about 800 hours. A fluid test at 400 will tell me if it needs changed but I doubt it. Most of the hyd. oils have a 2000 hour min life, the brakes would be the main source of contaminants and I never use them except as a parking brake. CJ
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2017 Komatsu PC490-11 Hydraulic Excavator, S/N A41596, PIN# KMTPC251JHWA41596, Turbo Diesel Engine, (A59076)
2017 Komatsu...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
SKID STEER ATTACHMENT HAMMER (A58216)
SKID STEER...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
