DK35se Drain plugs
/ DK35se Drain plugs #1
Yota_85
Western Mass
Kioti DK35se
I've been meaning on asking this for a while, just keep forgetting.
On my DK35se there is another drain plug right next to the engine oil pan drain. (on the passenger side if you will) What's that for? I've never messed with it.
When I changed my tranny fluid, I changed both oil filters, and used the drain plug near the rear of the tractor only. The manual mentioned another drain near there but the diagram in the manual is vague. Was under there this morning and noticing that other drain reminded me to post here. What's that drain for?
/ DK35se Drain plugs #2
I can only tell you for a DK45 there is another drain plug near the engine and it's painted orange this is another transmission drain and must be drained also.
/ DK35se Drain plugs #3
There are two oil drain plugs on my DK40se, one on port the other starboard. Different motor I know but check to make sure on yours. Both should be opened for an oil change.
Check your owners manual.
/ DK35se Drain plugs #4
The oil tank had 2 halves. If you only drain one side you'll miss about 1/3 of the oil. I'm not sure but I'll bet the oil pickup had 2 inlets to keep the engine from starving for oil when it gets into some of the strange positions tractors are apt to get into.
(4) 12-16.5 Tires and Rims (A65640)
(4) 12-16.5 Tires...
2022 EZ-GO ELITE...
20ft. x 8ft. Shipping Container (A65640)
20ft. x 8ft...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
Parker 500 Auger Grain Cart (A66285)
Parker 500 Auger...
Landhonor Plasma Cutter (A66408)
Landhonor Plasma...
