DK35 starting problems
/ DK35 starting problems #1
Roscoe294
I have a 2004 DK35 with just under 1000hrs and here is my problem...
I turn the key to the "warm" position and the preheater relay box makes an audible buzz and also vibrates.
All normal lights illuminate on the dash but at the same time, the tach jumps around a little in the 1000rpm range.
I turn the key to the "start" position and the lights go out on dash and engine doesnt turn over.
Upon turning the key back to the "off" position and with the key "off", I hear a buzzing/humming under the drivers console/dash board.
The battery and ground are good but upon checking the connections and after trying to start the tractor, I found the positive terminal hot to the touch.
I unplugged the preheater box and still get the same result minus the buzz/vibration.
I replaced the ignition switch and swapped the two identical relays on the firewall by the fuel tank and still have the same problem.
Thanks in advance for your help
/ DK35 starting problems #3
Pos battery wire terminal bad ,or bad battery
/ DK35 starting problems #4
Load test the battery before you go any further.
It WAS a bad battery
THANKS FOR YOUR HELP
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
2012 International Prostar (A63118)
2012 International...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
New/Unused Wolverine 43in Mini Rock Bucket (A65583)
New/Unused...
2022 EZ-GO ELITE...
