3-Point Hitch DK35 hitch problem?
/ DK35 hitch problem? #1
go2weiss
2005 Kioti DK35
I have a great 2005 DK35. Only problem is an engineering defect which has been corrected on newer models. The yokes on the stabilzer arms snap under stress with virtually every implement I use. This is regardless if hoe they are adjsted etc. Any ideas?
/ DK35 hitch problem? #2
:welcome:
I'd go to the dealer and have the upgrades provided. The least they could do for you.
What did they do different on newer models?
/ DK35 hitch problem? #3
Not sure why you have have so many break?
I have an older model DK 35 with the same stabilizer arm setup.
I broke one yoke several years ago when I caught a big rock with the outside edge of my backblade.
I replaced it with a new one (around 10 or $15 I think) never had any more break.
Thanks for your quick response. Not sure either. My dealer says it was a poor design which has been improved. It is inexpensive to replace but just an ongoing hassle! I have questioned myself as far as adjustments on implements etc but regardless, I seem to break one every 10-15 hrs of bush hogging or blading...frustrating, I may look to a different type set up vs factory standard.
/ DK35 hitch problem? #5
I was on the Kioti site looking through the new DK 35se sales brochures.
Hard to tell from the pictures, but I'm not seeing a new design. The stabilizes arms and mounts to the lift arms still look the same to me.
/ DK35 hitch problem? #6
Have you tried adjusting them with some play in them? Acts a little like a shock absorber.
