DK series HST H-M-L reset sequence
   / DK series HST H-M-L reset sequence #1
airlynch
Meatloaf Mtn WI
Kioti DK45SE HST
Hello
Could someone post the DK series reset sequence for HST range selections? I believe it is in the shop manual.
Thanks
   / DK series HST H-M-L reset sequence #2
What do you mean? Isn't it just a lever to switch between ranges?
Shop manual has a reset sequence for HST that I am looking for.
I think I found it, maybe .....
To reset a Kioti DK Series tractor's HST (Hydrostatic Transmission), you'll need to ensure the tractor is in neutral, the engine is off, and the brake is engaged, then turn the key to the "on" position, wait for the dash lights to cycle, and then turn the key back to the "off" position.
Here's a more detailed breakdown:
  • Safety First: Always ensure the tractor is parked on a level surface, the engine is off, and the parking brake is engaged before attempting any reset procedure.
  • Neutral Position: Make sure the tractor is in neutral before starting the reset sequence.
  • Key Position: Turn the ignition key to the "on" position (without starting the engine).
  • Wait for Dash Lights: Allow the dashboard lights to cycle and stabilize.
  • Turn Key Off: Once the lights are stable, turn the ignition key back to the "off" position.
  • Start Tractor: You can now start the tractor and test the HST operation.
   / DK series HST H-M-L reset sequence #5
Interesting.
What does the 'reset' actually do to/for the HST transmission?
   / DK series HST H-M-L reset sequence #6
Ya, no idea what this does.. unless maybe its to reset any dash light gear selector indicators?
It's my big weekend project.
I expect a 42% torque increase on the back end of the curve.
Will post the reports after the dyno sesh. ;-)
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
154 (A52708)
154 (A52708)
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
Gas Engine Water Pump (A57454)
Gas Engine Water...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
