dk-65 hydraulics real jerky
   / dk-65 hydraulics real jerky #1
paulssigns
tym 400
both loader and backhoe real jerky.just purchased,changed fluid and filters seems to be sucking air.fluid is foamy.any ideas?
   / dk-65 hydraulics real jerky #2
Check fluid level on dip stick. Check hydro filter on tight with good seal. Check quick-disconnect fittings.
fluid on dipstick good,filters tight.i;ll check quick connects.thanks
   / dk-65 hydraulics real jerky #4
Sounds like an air leak from the suction side of the hydraulic pump. Where it sucks fluid from the tank to the pump it is also sucking in air. If this was a Kubota L3400 I could tell you exactly where to look. Since it is not, I cannot tell you where to look, but this is what I think is wrong with it. it is sucking air.
James K0UA
   / dk-65 hydraulics real jerky #5
Fluid should not be foaming. What fluid did you use, how much did you use? OEM filters? Hours on tractor? What year tractor? Give us more basic info. DID you do the filter and oil changes?
tractor 2006,260 hours did it when i purchased,i changed filters ,kioti filters
   / dk-65 hydraulics real jerky #7
I don't have a manual for your tractor. But looking at similar schematics, it appears that the hydro pumps suck the oil through the filter. Hence, any air leak at the filter (bad gasket, debris, etc) could produce your symptoms. Might be worth checking. Other potential leak points are under positive pressure so less likely to suck air.
fixed it.the tube between the rear and the filter housing has an o ring on each side the top one near the filters was bad.2 new o rings fixed it.
   / dk-65 hydraulics real jerky #9
Thank you for posting back the results.. I figured an air leak.
   / dk-65 hydraulics real jerky #10
Great! How did you find the location of the problem? This could be useful info for others, too.
Kubota RTV X900 (A53317)
Kubota RTV X900...
cummins generator (A56857)
cummins generator...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
