DK 4210 dead...
   / DK 4210 dead... #1
Northernman
Kioti DK 4210 - Cab
Hello all, I have a 2020 DK4210 Cab with no power to the instrument cluster, no lights, NOTHING...
Battery is at 12.5 V and I have power to the starter
Does anyone have a checklist ?
   / DK 4210 dead... #2
Well, first thing would be to check the fuse goin' to the instrument panel. Check for power on both sides, or if it's the kind with no test spots ohm it out.
   / DK 4210 dead... #3
check alternator wires, happened to me
   / DK 4210 dead... #4
Details details….what happened to you? Can you describe what you did to fix the issue? That’s really beneficial to everyone on any forum…🤷
   / DK 4210 dead... #5
I had the same thing occur on my 2018 CK3510. It ended up being a loose ground on the frame. Check that ground and make sure it’s not loose. Mine was located on the right/front side of the frame, near the starter. Hope you get it running soon.
   / DK 4210 dead... #6
Did you find the problem? Mine was similar- got a code, selinoid would click but battery would be down to 50% or less by next day. The battery voltage was good, but the amps were way low. Replaced the battery and it is working fine (this happened after 1 month of owning) I’m wondering if it is overcharging though as I’m around 14.25 bolts when it’s running?
   / DK 4210 dead... #7
14.2 volts is normal. Check your car for example…
1985 Wilson Hopper Bottom Trailer (A50514)
1985 Wilson Hopper...
Land Honor Quick Attach Articulating Boom Brush Cutter (A50514)
Land Honor Quick...
(2) 18.4-34 TRACTOR DUALS (A51244)
(2) 18.4-34...
Year: 2010 Make: Chrysler Model: Town & Country Vehicle Type: Van Mileage: 140,803 Plate: Body Ty... (A50324)
Year: 2010 Make...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
2019 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
