DK 4210 dead...
   / DK 4210 dead... #1
Northernman
Kioti DK 4210 - Cab
Hello all, I have a 2020 DK4210 Cab with no power to the instrument cluster, no lights, NOTHING...
Battery is at 12.5 V and I have power to the starter
Does anyone have a checklist ?
   / DK 4210 dead... #2
Well, first thing would be to check the fuse goin' to the instrument panel. Check for power on both sides, or if it's the kind with no test spots ohm it out.
   / DK 4210 dead... #3
check alternator wires, happened to me
   / DK 4210 dead... #4
Details details….what happened to you? Can you describe what you did to fix the issue? That’s really beneficial to everyone on any forum…🤷
   / DK 4210 dead... #5
I had the same thing occur on my 2018 CK3510. It ended up being a loose ground on the frame. Check that ground and make sure it’s not loose. Mine was located on the right/front side of the frame, near the starter. Hope you get it running soon.
   / DK 4210 dead... #6
Did you find the problem? Mine was similar- got a code, selinoid would click but battery would be down to 50% or less by next day. The battery voltage was good, but the amps were way low. Replaced the battery and it is working fine (this happened after 1 month of owning) I’m wondering if it is overcharging though as I’m around 14.25 bolts when it’s running?
   / DK 4210 dead... #7
14.2 volts is normal. Check your car for example…
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2018 VOLVO EC480EL EXCAVATOR (A52707)
2018 VOLVO EC480EL...
2015 Ford Transit 250 Cargo Van (A53422)
2015 Ford Transit...
Mini Margaritaville Truck (A55853)
Mini...
2013 International WorkStar 7400 Altec AM650 50ft Material Handling Insulated Bucket Truck (A55852)
2013 International...
2020 Mathieu MC210 Azura Flex Street Sweeper (A55851)
2020 Mathieu MC210...
