DK-40 2 questions.....
/ DK-40 2 questions..... #11
EASY. Two 10mm nutz on the firewall. Push down on the tab in the middle of the connector and wiggle the display unit loose- they tend to be stuck tight to the connector. I put some Vaseline on the outside of the female,(white) connector, so they would be easier to separate if needed in future.
How do you reach Tom Martell?
Thx,
CM
I will sent you PM tonight, if I remember!
/ DK-40 2 questions..... #12
I don't have a block heater on my '40 and is lives outside under an open shed. It will always start in sub freezing(low teens to single digits) weather if I cycle the glow plug circuit 3 times. If I only cycle once, the engine chugs and clatters excessivly.
Have y'all noticed the steering wheel gets frozen in place until the engine warms up a bit?
RD
Yes, the wheel will tend to freeze up, on both my former DK-35 and now my DK-40. Michigan Iron & Equip. mentioned, when I brought this issue up on the 35, that there is a kit that can be installed to help prevent freeze-up.
I've decide to live with it since it cures itself after warm-up.
Giyi GY-DHC Quick Attach Forks (A60463)
Giyi GY-DHC Quick...
LMC Ag 25 Gallon Sprayer (A60463)
LMC Ag 25 Gallon...
2019 FORD F-350 FLATBED (A60736)
2019 FORD F-350...
Bush Hog 2212 (A60462)
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
