DIY Utility Vehicle
/ DIY Utility Vehicle #21
When you say parasitic losses in the power train, what do you mean? I figured I would probably loose 2-3hp through the pillow blocks, torque converter, and reverse gearbox, however not "parasitic" loses. Am I underestimating this, or is there something else that I am missing.
Those items to me are parasitic losses, along with alternators, etc. No power-train is 100% efficient; but gears are more efficient than belts or hydrostatic drives.
I think $1,000 plus engine cost may be a stretch; but that depends on how frugal and resourceful you are.
In any case, it's obvious the build is what interests you the most, and if it functions as you hope for that is icing on the cake.
These TBN threads may be of interest to you.
http://www.tractorbynet.com/forums/build-yourself/221521-another-mini-dozer.html
http://www.tractorbynet.com/forums/build-yourself/231125-scale-cat-twenty-two-dozer.html
There is a disabled member whose screen name begins with a "K" that is building an articulated ATV that he operates from his wheelchair. I'm having a brain fart tonight and I'm coming up empty finding the thread.
/ DIY Utility Vehicle #22
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
CASE 105C (A62177)
CASE 105C (A62177)
1789 (A64280)
1789 (A64280)
