DIY TX1510 add external hydraulics for mower rotor
   / DIY TX1510 add external hydraulics for mower rotor #1
Ernie-32
Southern France
Iseki TX1510F, Case IH 845A
Anybody knows what, where, how to add the external hydraulic line connectors on an Iseki TX1510? Would it be powerfull enough to activate a hydraulic rotor of a small (80cm) mower blade? I'm considering to add to my tractor this feature below, which is a fence pole mower. But I wonder is my little Iseki is capable of working with this. Don't know (yet) how much Liter/minit it needs.
Information of all sorts very welcome. Like which tube to cut, where to add a split for an extra tap. Where to buy this stuff?
There is also a PTO-version, but that makes the installation much more expensive (2500€ in stead of 1700€) and why power an external hydraulic pump if you allready have one on the tractor?
   / DIY TX1510 add external hydraulics for mower rotor #2
I don't think you have enough flow to run that setup. Mine is slow with just a loader! PTO setup is the only way to make that work. I don't remember the exact flow rates, but remember them being below 3 gpm. You can have a manifold for the plate under seat to give you an in and out. It's hars to find factory ones, but know someone that could provide you an aluminum one. I have a Bolens G1502 and a White 1704.
Thanks for your quick reply Topsize, if indeed you mean us-gallons that means only 11 L/min can't be enough to power a hydraulic rotor. But then again also imperial-gallons at 14/min would not be enough.
Good to be warned for that, I'll have to look into the PTO version and won't bother to change hydraulics on Iseki.
   / DIY TX1510 add external hydraulics for mower rotor #4
The hydraulic pump is 5 gallons per minute. I can supply a slightly larger pump. To add a remote, cut the pressure line & run the pump side to the IN on the remote & the OUT to the back end. If using a power beyond valve. run the OUT to the transmission case & the PBY to the back, The other alternative is to use a PTO pump.
Thanks for that info Lens12, would you happen to know the pressure available by the Iseki pump? So according to metric standards it would produce even 25L/min.
   / DIY TX1510 add external hydraulics for mower rotor #6
I don't know the metric comparison. They would produce over 2000 psi. The relief valve determines the system pressure.
okay, that's not so bad at all 137bar! Have a look at this link if anytime you need any conversion between all kinds of measures even money, volumes, distances etc :
   / DIY TX1510 add external hydraulics for mower rotor #8
iseki tx1500 oilpump is documented as 1707 PSI.
Long time ago i found some documentation that stated a flow of 10L /min.
Your TX1510 uses the same oil pump if i am correct, so the specs would be more or less the same...
M.
8ft. S/A Utility Trailer (A55853)
8ft. S/A Utility...
2013 Ford F-150 (A53422)
2013 Ford F-150...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A57193)
UNUSED FUTURE MINI...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
