DIY TX1510 add external hydraulics for mower rotor
   / DIY TX1510 add external hydraulics for mower rotor #1
Ernie-32
Southern France
Iseki TX1510F, Case IH 845A
Anybody knows what, where, how to add the external hydraulic line connectors on an Iseki TX1510? Would it be powerfull enough to activate a hydraulic rotor of a small (80cm) mower blade? I'm considering to add to my tractor this feature below, which is a fence pole mower. But I wonder is my little Iseki is capable of working with this. Don't know (yet) how much Liter/minit it needs.
Information of all sorts very welcome. Like which tube to cut, where to add a split for an extra tap. Where to buy this stuff?
There is also a PTO-version, but that makes the installation much more expensive (2500€ in stead of 1700€) and why power an external hydraulic pump if you allready have one on the tractor?
   / DIY TX1510 add external hydraulics for mower rotor #2
I don't think you have enough flow to run that setup. Mine is slow with just a loader! PTO setup is the only way to make that work. I don't remember the exact flow rates, but remember them being below 3 gpm. You can have a manifold for the plate under seat to give you an in and out. It's hars to find factory ones, but know someone that could provide you an aluminum one. I have a Bolens G1502 and a White 1704.
Thanks for your quick reply Topsize, if indeed you mean us-gallons that means only 11 L/min can't be enough to power a hydraulic rotor. But then again also imperial-gallons at 14/min would not be enough.
Good to be warned for that, I'll have to look into the PTO version and won't bother to change hydraulics on Iseki.
   / DIY TX1510 add external hydraulics for mower rotor #4
The hydraulic pump is 5 gallons per minute. I can supply a slightly larger pump. To add a remote, cut the pressure line & run the pump side to the IN on the remote & the OUT to the back end. If using a power beyond valve. run the OUT to the transmission case & the PBY to the back, The other alternative is to use a PTO pump.
Thanks for that info Lens12, would you happen to know the pressure available by the Iseki pump? So according to metric standards it would produce even 25L/min.
   / DIY TX1510 add external hydraulics for mower rotor #6
I don't know the metric comparison. They would produce over 2000 psi. The relief valve determines the system pressure.
okay, that's not so bad at all 137bar! Have a look at this link if anytime you need any conversion between all kinds of measures even money, volumes, distances etc :
   / DIY TX1510 add external hydraulics for mower rotor #8
iseki tx1500 oilpump is documented as 1707 PSI.
Long time ago i found some documentation that stated a flow of 10L /min.
Your TX1510 uses the same oil pump if i am correct, so the specs would be more or less the same...
M.
Hustler 60in Zero Turn Commercial Mower (A55851)
Hustler 60in Zero...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
(4) 14" X 26# X 158.5" I BEAM (A57192)
(4) 14" X 26# X...
John Deere 5055E (A53317)
John Deere 5055E...
2019 CATERPILLAR 272D2 XHP SKID STEER (A52707)
2019 CATERPILLAR...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
