DIY Electric chute rotator
   / DIY Electric chute rotator
Wyld Bill,
I'll see if I can come up with some way to get some pictures, but every cheap winch and every snowblower is different. The sprocket were some heavy chain surplus I had laying around. Places that sell power transmission drive systems would be a good bet. I would think McMaster and or Grainger's also. My setup is on a loftness 5' unit. I think the hand crank was a standard 1" bore and the winch sprocket had to be bored to just over 2" to fit on the spool. Since I used sprockets I had lying around, I had to live with the speed I got. My blower will got 360 degree rotation, no stops. I would guess it is about 20-25 seconds to go from side to side (> 180 degrees), but if I had a different sprockets I could have sped it up. It is still quicker than getting turned around to do it by hand!
On the question of chute closure control, I also run basically wide open, I probably close mine down once or twice a year when it is really blowing. I still would go the surplus linear actuator unit route just to be as clean and compact as possible if I ever get to it. Probably would cost a little bit more, but they are getting more popular.
Actually ever cheap 2000# winch I looked at on-line was made in China by the same company then relabeled in the US.
Boy that seems slow to me.
How many turns on the crank to rotate the chute 360 degrees??
Must be a cable rotator off the shaft huh?
   / DIY Electric chute rotator #32
from WYLD BILL:
I keep reading about linear actuators for the chute angle/deflector control. Why?
If the winches work good why not just install a heavy torsion (like on a mouse trap but much larger) spring on the deflector that is trying to push it shooting snow towards the ground. Mount a winch somewhere on the chute wth the cable clipped onto the deflector (most deflectors already have a tab here for manual settings). Power the winch in & the deflector moves up shooting the snow more vertical. Power the winch out & the spring pulls the deflector downward. DONE! Another cool thing is of something solid hits the deflector like a big rock or something, with the torsion spring pushing down the deflector would "give" a lttle to absorb the blow.
Actually was just thinking why couldn't you just use a heavy duty control cable of some sort to control the deflector. Similar to some walk behind blowers. No motors needed.
__________________
Have been on same thought trend--
I came up with parking brake cables as a source.
but they only work in 'pull' mode, not stiff enough to push.
They need a guided rod to push.(maybe spring loading to 'open' might work)
Biggest push/pull 'bowden cable' I could find was truck PTO push/pull cables and that is still marginal enough that I did not try it.
Re shock absorbing the shute; other than blasting the paint even 4 inch rocks won't damage a shute. (I know!)
On my shute, presently I installed a large turn buckle for easy adjustement for the few times I need to adjust but generally run wide open.
WET SNOW trick:
Fab a plastic liner for the snow shute!
Heat PVC with a plumber torch, fold edges over wood plank to conform to shute dimensions and attach with small bolts/body washers at bottom of shute.
Sand gravel won't damage and snow/slush wont stick nearly as well as to cold steel.
I would think that truck paint on 'body liner' would also work.
   / DIY Electric chute rotator #33
If the winches work good why not just install a heavy torsion (like on a mouse trap but much larger) spring on the deflector that is trying to push it shooting snow towards the ground. Mount a winch somewhere on the chute wth the cable clipped onto the deflector (most deflectors already have a tab here for manual settings). Power the winch in & the deflector moves up shooting the snow more vertical. Power the winch out & the spring pulls the deflector downward. DONE!;) Another cool thing is of something solid hits the deflector like a big rock or something, with the torsion spring pushing down the deflector would "give" a lttle to absorb the blow.
Interesting, I never thought of that I believe an old or new garage door spring would do well for the spring in this application.
I would further consider possible the winch to pull the chute rotation.in the same manner with a heavy spring to hold the chute in the opposite position.
from WYLD BILL:
__________________
WET SNOW trick:
I was thinking something like a cable off an old plow system like a Fisher. Yeah a parking brake would work great. The cogs would hold it in place against a spring pushing it down. Hard to make quick to disconnect for the year though.
   / DIY Electric chute rotator #35
When I decided to add rotation and chute elevation to my Woods snowblower I went the Winch route and ended up buying it off from Ebay for around $30.00 inlcuding shipping.
You can see the connection to the Woods chute rotator.
This winch had a hole in the outside end that I could mill down a 1 1/4" aluminum pipe to fit into. Then I drilled a hole through the winch and pipe to secure it in place.
I used the winch control and wired it so I could mount it on the plexiglas I have mounted across the back of the ROPS (used tie wraps so it is easy to take off in the spring) The yellow one controls the chute rotation and then there is a black box above that controls the linear actuator that is conected to the chute deflector.
This year I picked up a 51/4" stroke 12 VDC linear actuator off from EBAY and it is what I use for the deflector. Works just fine.
Oh Iike that. Looks very factory! What supports the other end of the winch drum though? Did you loose the freespool feature of the winch? Did the snowblower chute rotator already have a U-joint or did you add that yourself?
MORE PICTURES!:D (With less snow blocking view)
   / DIY Electric chute rotator #37
I've been thinking about the winch cable setup to rotate my chute and do it like bluecon did.
I'm going to have to get the winch at HF next time its on sale.
The other thing I've thought about is using the 12v scissorsjack at HF and modify it to make a linear actuator for the spout. Then I just found another thread about this and someone found a regular 7" actuator for around $30. Gotta find that one on ebay ,thats less than the HF jack and no mods needed.
I also like the plexi on the ROPS, keep some of the stuff of you.
   / DIY Electric chute rotator #38
I have a Woods SS-60 snowblower and the u-joint was already on the chute rotator. So what I did was add a plate to hold the winch and then adapted the aluminum pipe to fit inside the drum on the winch and the other end to fit into the u-joint.
Last year I purchased the first winch off from Ebay and adapted it to work with the chute. It worked okay, but the winch was really cheap and it wasn稚 easy to connect up to. I ended up using it but this past summer I found another winch, again on Ebay that someone had taken off from his 4-wheeler and it had the opening on the end where that was much easier to modify.
This is the first winch I purchased and used the yellow controller:
eBay Motors: WINCH KUBOTA RTV 500 900 RTV900 1100 JOHN DEERE GATOR (item 300285168656 end time Jan-12-09 22:41:23 PST)
These are manufactured in China, really a piece of junk! But, when I bought it I paid like $35 plus shipping for it, so it was cheap. The second one was much better and about the same price, but it had been used!
Wayne
   / DIY Electric chute rotator #39
One source for cheap linear actuator is the actuators that were used on the 8 and 12 ft satilite dishes, while actually 24 volts they work fine at 12 volts, just slower.
However they are usually 24" long and would need cutting, but the basic mechanism is there!
A bonus is they were made for operation out in the elements!
   / DIY Electric chute rotator #40
Wow that is interesting, have any idea where to look for these items? Wayne
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
