Diy drag
/ Diy drag #1
mwemaxxowner
Platinum Member
Pageland, SC
BX 1880 with FEL and canopy
Okay, by no means is this really worthy of a "do it yourself". I'm aware all I did was pop a few screws and attach a chain. BUT. I had been doing some grading and felt I was at a point where I had done all I could do with the tractor, and I needed a drag or to start working it by hand.
Well, I have this old tractor tire I will flip for exercise, and some old treated 4x4x8 posts, so I put this together with a chain and drug it around and it actually worked really well!
I needed to throw something together with what I had on hand. First I tried to just screw one 4x4x8 to my (~30') chain with a long length behind the post but it didn't do much. This actually works! By no means did it eliminate all hand raking but it made it minimal.
/ Diy drag #2
Nice work! The only problem I see; you can't back it up. :ROFLMAO:
/ Diy drag
I definitely can't back it up. Haha. I was very careful with my lines and a time or 3 I had to get out and man handle it over one way or the other.
I can lift or lower the 3ph though depending on the situation to adjust the aggressiveness of that front 4x4.
I would like to pair this with a boom pole to lift the back and then I might really be able to back up.
/ Diy drag #6
This is my DIY land leveler pulled from the scrap pile:
/ Diy drag
I enjoy seeing your unique tractors.
/ Diy drag
I really like the idea of the cattle gate as a leveler. I've priced gates recently, I want to add one to my shed I park my trailers and tractor in.
They're priced such that I even think it would be worth buying a new one for this task, if it works that well.
/ Diy drag #10
Old piece of train track, skidder tire chain cut in 1/2 and a piece of tubing of some sort….
/ Diy drag #11
Here's one I made years ago out of scrap I had.
I just bought some Rough sawn oak 4x4's last week in MO. to replace the old treated pine ones that are cracked, broken and worn out. It has provisions to add some weights to it, although these new oak posts are so heavy, probably won't need to use any.
I'll have to take another picture this weekend of it in use when I replace the 4x4's
/ Diy drag #12
Here it is as Rev2. Upgraded the hitch so it can be backed up and near 90 degree turns can be made without hitting the wheel of the JD or ATV.
/ Diy drag #13
A 3-"blade" version should be better than the common 2-blade type. All the weight will be on the center when crossing a hump for better cutting. And the center will be suspended at a dip, letting the material go under to fill the dip.
Bruce
/ Diy drag #14
ilogs...i do have a set of chains with the ring cleats in them. They are about worn out as far as logging. Came with out Bell Feller Muncher. Yep, we still use one.
/ Diy drag #16
Here's one I made to lightly drag soil over seed that needs a shallow cover. Angle iron, old tire chains and a piece of PVC pipe.
/ Diy drag
I was working on the lawn today and needed something a little less aggressive. This worked pretty well. I can lay my big tire on top if I ever need to.
/ Diy drag #19
I've made a few.
Both in wood and steel.
Always 3 blades with the center angled so as to 'slice' humps and move the material over to the dips. If the surface is very 'hard packed' teeth can be added on the front blade.
We maintained a well travelled 3 mile dirt road for some 12 years with such a rig while towing behind an old Willis Jeep.
For shock absorbers we used old 12 inch tires and linked the tow chains thru them.
We used 2 chains for better directional control.
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
JOHN DEERE 8360R TRACTOR (A63291)
JOHN DEERE 8360R...
4021 (A59228)
4021 (A59228)
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
