DIY Digging trenches for Geothermal
/ DIY Digging trenches for Geothermal #122
Wow. I use about 14 a day or less on average for the whole house .... everything.
What is your HVAC system?
How big is your house?
Where are you located?
Water heater, Stove, dryer? all electric?
How many people live in the house?
Comparing electric usage is really pointless without knowing a single detail other than usage. I use 80-100 per day in the winter. about 40/day in the spring and fall, and about 60-65 in the middle of summer. But all electric, 2 kids (so lots of baths/showers/laundry) lots of cooking, etc.
Heck, my shop thats on a separate meter....about 7 a day even if I am NEVER down there. Just a fridge, 175w dusk to dawn, and a few battery chargers.
/ DIY Digging trenches for Geothermal #123
100 kWh per day..... thats kind of insane. My house is all electric also, minus a wood stove for primary heat. We use 15-20 kWh on a normal day, and up to 30 kWh if we run the electric clothes dryer multiple times. You should find out whats causing a 7 kWh phantom load in your shop, and put a switch on it. A fridge should only use a couple kWh, max. They don't run continuously....
Things you could look into: Get LED light bulbs, as they do add up. Get energy star appliances. And a heat-pump water heater is WAYyyyy more efficient than a standard electric unit. I wish someone made an affordable heat pump clothes dryer, too.
/ DIY Digging trenches for Geothermal #124
Windows, fans, one window A/C in Summer, wood stove and LP Forced air in Winter
1200 SqFt or so.
Moderate climate
Electric, Gas, none --- outdoor line.
1
175w dusk to dawn
That's a big part of it. All of my outdoor lighting combined, all four sides of the house and yard consumes only about 50 watts total. It's not exactly daylight, but it's enough that I can see clearly and most everything is visible on the cameras.
We are in South Carolina and it is dominantly cooling climate. My Geo is running now using 1.6 KW.
I could not be happier. The AC system that was installed when my house was built used 4.3 KW and it was a single speed system.
That is more than double the power usage and did not control the humidity very well.
Most homes here have higher cooling bills than heating. I have higher heating than cooling and use the extra solar power we make bank it for winter usage.
We keep our house pretty much 75 degrees year around.
We have solar power and the last seven years we have production daily average 47.8kWh 53.8kWh
This also covers my EV car for 17k-20k miles a year.
/ DIY Digging trenches for Geothermal #126
You guys are mistaking me stating my usage as complaining.
Our rates are modest. And my usage is normal for what I do.
At the shop, the 175w light accounts for about 3kwh a day, so the fridge and the few 18v chargers, and DC wall charger things must account for the remaining 4 kwh. Usage goes up to 30-40/day if im down there all day with lights on, welding, running the phase converter so I can run the mill or lathe, 10hp compressor. furnace blower in winter or two window units in summer.
House usage....all justifiable. Two adults and two kids. Usually 3 showers and 1 bath a day, sometimes 2/2, so thats alot of hot water. (and no I dont use them water saving heads that barley trickle). Lots of Laundry. Usually two outfits a day for the kids. (school clothes and home clothes) Oven running ~1hr a night + stovetop. A few hours every evening consists of probably 3 TV's and a computer all going, not to mention the ~4000gph pond pump that runs 24/7. Two porch lights are always on, bedroom ceiling fan,.....etc etc. It all adds up.
My rolling 12-month average for my bill is $210. My average monthly usage for last 12 months is 1663kwh.
The only variable that changed in the last 4 years for the house is switching from baseboard heat to geothermal. Baseboard heat was ~$450/month and 4000-5000kwh/month usage.
Again, not complaining. Just stating that all of us arent uptight about electricity usage
Again, Im not complaining, and Im not looking for suggestions to lessen my usage. House is all LED's, thats the extent of my caring.
@LD1
We are not that far off our usage. You have a shop like me. I do welding projects run my plasma cutter.
Have Aquaponics system that has a pump 1200 GPH runs for my system year around. I also heat the water in the winter.
I also have two kids. All similar. My car probably is what puts my usage higher than yours.
Here is my solar production and only two last years we did not zero out for the year.
We had so much rain last year (about 25 year high). Dropped us from 18 – 19 Mw to 17.4 Mw.
We also had the boys come into driving ages and used/charged our car more.
This year we have geothermal and sold our pool even know I had a variable speed pump it will be better not running it.
April, we banked 363 KWH and this month we are at about 400Kwh more to bank.
I like to go into winter with about 3,000 Kwh banked to help for heating.
/ DIY Digging trenches for Geothermal #130
So, a little of both. That's where wind turbines can come into play. They generate power on those cloudy, stormy days when Solar panels can't. For some reason, I don't see too much discussion of hybrid wind/solar systems for homes though.
We don’t have enough wind here for turbines and turbines for the home owner it is not a very good deal. To much maintenance and solar has come down so much in price wind can’t compete just add some more solar.
If you do a DIY install and use the tax credits solar has a pretty fast payback time.
The other day I got out my tractor and planted some grass seed.
We finally got some rain and the grass seed has started growing.
The Geothermal Ac is working really well and the two stage compressor is great.
Stage 1 can handle to about 95-96 outside then stage 2 comes on that is about right.
This keeps the humidity at a very comfortable level.
/ DIY Digging trenches for Geothermal #133
It will get better over time as the dirt settles on the geo lines.
/ DIY Digging trenches for Geothermal #134
If you have section on copper on the in and out you can put thermometer each then insulate and you should see about 10' difference.
I have a two-way communicating thermostat that gives me all the system info.
No need to connect up anything else.
/ DIY Digging trenches for Geothermal #136
I am no expert, but everything I have read, and everyone in the HVAC business I have talked to, said 2-4 degrees is about the norm.
You won't see a huge difference in supply and return loop temps, because of the shear volume of water flow. If the flow is slowed waaayyy down, then maybe you would get a 10 degree Delta.
/ DIY Digging trenches for Geothermal #138
My loops are currently 5, 8, 7, 7, 7 degree different.
/ DIY Digging trenches for Geothermal #139
Early into either season the larger differences is understandable. Early into winter the ground hasn't cooled as much and more heat to be had. Same in the summer. Later into a season the differences diminish.
Are you guys running one pump or two? Pressurized or non?
I have one three speed Grundfos UP2699FC pump. My system is pressurized. 4 loops one pump.
I dropped the pump down to medium speed for the summer. The winter it needs to be on high.
We just went through a couple week heat wave much higher than normal (for this time of the year). 97-89 degrees.
That raised my loop temp some but this is my first summer so I really don’t know what loop temps I will see.
