DIY counter weight
/ DIY counter weight #41
Including the weight of the operator, you're golden. Not too long ago a pic was posted of a skidoo being moved by an FEL with fork extensions, no ballast. When the operator dismounted the tractor, one rear wheel rose up off the ground.View attachment 636331
https://www.tractorbynet.com/forums/owning-operating/314547-stepped-off-almost-tipped-over.html
Yeah.....
Guess what happened when I took my 220 pounds off operators position....
This started my adventure into ballast.... According to spec sheet the JD L120 weighs 520 pounds. A bit less than the FEL lift capacity- think about it... ...
Dale
/ DIY counter weight #42
Yeah.....
Dale
With that tractor hanging 4-5 feet off your bucket like that the effective force is far more than 530 pounds, probably more like 750 or more. 500 or 600 pounds in the bucket won't do that.
/ DIY counter weight #45
Would that be a FEL mounted mower deck.?:D:drink:
/ DIY counter weight #46
That weight box turned out good, and you even hooked it up to a 3 point quick hitch.
What do you have planned for the 2 pvc through conduits that are cast into the weight box?
KC
Conduits go thru front to back so I can bolt on a steel z channel so I can hang the weight on the FEL pallet fork rack or the rear 3pt pallet fork rack when the forks are removed.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
ROANOKE LONG ARM DITCH BANK MOWER (A63291)
ROANOKE LONG ARM...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2025 Dingo Ditch Bucket Skid Steer Attachment (A61572)
2025 Dingo Ditch...
2023 John Deere 333G Track Loader (A63111)
2023 John Deere...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
