DIY Cab for Kubota B2620
   / DIY Cab for Kubota B2620 #31
Mot sure how similar your tractor is, but mine was easy to plumb into the bypass. There's a short 90* shaped hose that's 5/8" on the end that connects horizontally and a smaller one that points down. It was simple to disconnect the 5/8" end and swing it in the opposite direction and couple onto it. The other heater hose is connected into the spot vacated by the short factory hose.
I installed 3 valves near the heater so it can be shut completely off with 2 of them and the third short-circuits the heater for a bypass.
Thanks Chim. I do have something similar bu th not sure of the hose diameter. If I don't get a definitive answer, I'll take it apart and check the dimensions.
   / DIY Cab for Kubota B2620 #33
nice work
Thanks. I'll try to get better pics soon. I got a little burned out on it but have ordered heater and wipers to put on it.
URL=http://s467.photobucket.com/user/GPintheMitten/media/20140211_104913_zps2yvfpqub.jpg.html]
[/URL]
   / DIY Cab for Kubota B2620 #36
GP... looks awesome! Well done. Visibility couldn't be better! Thanks for sharing.
Oh... but add more LED lighting! :D
Got one in the back too with red clearance lights.
It's actually pretty bright but I agree it would look better with 2 lights each front and back.
   / DIY Cab for Kubota B2620 #39
That really looks good.
Thanks for the cudos..it's not as pretty as some but it is functional.
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
MILWAUKEE 14" Abrasive Cut-Off Machine (A59076)
MILWAUKEE 14"...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
