DIY Cab for Kubota B2620
/ DIY Cab for Kubota B2620 #31
Mot sure how similar your tractor is, but mine was easy to plumb into the bypass. There's a short 90* shaped hose that's 5/8" on the end that connects horizontally and a smaller one that points down. It was simple to disconnect the 5/8" end and swing it in the opposite direction and couple onto it. The other heater hose is connected into the spot vacated by the short factory hose.
I installed 3 valves near the heater so it can be shut completely off with 2 of them and the third short-circuits the heater for a bypass.
Thanks Chim. I do have something similar bu th not sure of the hose diameter. If I don't get a definitive answer, I'll take it apart and check the dimensions.
Thanks. I'll try to get better pics soon. I got a little burned out on it but have ordered heater and wipers to put on it.
URL=http://s467.photobucket.com/user/GPintheMitten/media/20140211_104913_zps2yvfpqub.jpg.html]
[/URL]
/ DIY Cab for Kubota B2620 #36
GP... looks awesome! Well done. Visibility couldn't be better! Thanks for sharing.
Oh... but add more LED lighting! :D
Got one in the back too with red clearance lights.
It's actually pretty bright but I agree it would look better with 2 lights each front and back.
/ DIY Cab for Kubota B2620 #39
That really looks good.
Thanks for the cudos..it's not as pretty as some but it is functional.
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
FORKLIFT (A56857)
FORKLIFT (A56857)
2015 Komatsu HM400-3 (A60352)
2015 Komatsu...
2026 tilt trailer (A56859)
2026 tilt trailer...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
Pittsburgh Heavy Duty Solid Steel Auto Ramps (A59230)
Pittsburgh Heavy...
