DIY bucket
/ DIY bucket #1
Takman
Vermont
Old John Deere and new Takeuchi
I'm planning to build a 24" Scandi style bucket for my machine.
Just curious how you would go about bending the back plate/sheet metal?
/ DIY bucket #2
I made a 13" bucket for my homebuilt CADDigger years ago. To curve the 1/4" mild steel plate, I used 2 cable come-alongs and an O-A torch to heat it up a section at a time. As I bent it, I welded it to the side plates. Worked great.
24" is pretty wide. What I would do today is use a thinner carcass plate, 3/16 or even 1/8", and add wear plates to the outside of the curve. For yours, you could bend 2 pieces of plate, and weld them together in the middle. Wear plates can be a couple of inches wide, so they would be easy to bend.
/ DIY bucket #3
Agree with dfkrug. I made a skid plate for my haybine in a very similar manner. Take your time and do a nice job and you'll be pleased with your work. Or you could have a fabrication shop put a radius in it for you $$
3098 (A63117)
3098 (A63117)
SHOPBUILT MESH BOTTOM TRAILER (A64278)
SHOPBUILT MESH...
34in. Bucket with Teeth Excavator Attachment (A64194)
34in. Bucket with...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
JOHN DEERE 1770NT - 12R30" VACUUM PLANTER (A64278)
JOHN DEERE 1770NT...
