DIY Backhoe Bucket
/ DIY Backhoe Bucket #1
MasseyWV
Elite Member
I am in the process of purchasing a new Mahindra 3215 4WD with FEL and backhoe/16" bucket and anticipate the occasional need for a smaller bucket when trenching, etc... and have read a number of articles about building your own backhoe and began thinking that I might like to build my own (smaller) bucket to fit the Mahindra backhoe for use when a smaller bucket is needed.
Has anyone built their own bucket or have any suggestions about how easy or difficult it might be?
NOTE: I have all the equipment needed (torches, welder, etc...) and reasonable DIY skills.
/ DIY Backhoe Bucket #2
I made a 6" bucket for my backhoe, http://www.tractorbynet.com/forums/...69d1175554284-gc2310-attachments-100_0172.jpg
By the time I bought all the material, and spent time making it, I did not save any real money. Unless you cannot get the bucket you want, (I could not buy a 6"), You could be better off buying it.
To make a good bucket, you need very hard steel for the cutting edges and it is not cheap. If you can get scrap or drops form a local supplier, you might be able to make it worthwhile. Another option could be to buy a used bucket and modify it for your machine. Many Dealers have old, unknown usage buckets that can give you a good head start. Bushings to fit your machine can be bought at Tractor Supply Co.
If you want to dig clay soil, a bucket smaller than 12" is not recommended. The clay will not want to come out of the bucket when you empty it.
/ DIY Backhoe Bucket #3
Good suggestion, about buying one and modifying it. I've "been there, done that" on a few items. Never saved a dime. Had fun building though.
I too, want a narrower bucket for my JD410. There are times when a 12" or narrower bucket would come in handy. Don't know if I want the digging the stuck stuff from a narrow bucket PITA situation though. Reason I haven't gone less than my 16" bucket.
/ DIY Backhoe Bucket #4
i thought you could put release holes on the backside for smaller buckets so you dont get quite the suction effect.
/ DIY Backhoe Bucket #6
My bucket has the hole, it does not make a bit of difference. Spraying the bucket with various lubricants, and hanging piece of chain inside the bucket are also not the solution.
I have thought about a solution like the one shown in the ejector bucket thread, or a spring loaded mechanism to eject the spoils.
The biggest problem is it is just too easy to rent a trencher when I need a narrow trench. Fast, easy and the back fill is soft powder. So I don't mess with the 6" bucket.
/ DIY Backhoe Bucket #8
I built a 5" bucket based on the cad plans design. It was a total failure in my heavy clay soil - it took a long time to chip the concrete like compacted clay out of the bucket. I decided to use the bucket to remove small stumps, so I cut almost all of the back out, but the clay still compacted in the bucket. I finally removed some of the sides, and now it works great as a stump ripper. Also - since I use my buckets "occasionally", I don't bother with the super steel edges or teeth - I use regular steel, and if they ever wear out, I'll weld on something new - two backhoe buckets and a skid steer bucket, and no problems so far.
I am facing the same problem because I have an over abundance of rich clay soil.
/ DIY Backhoe Bucket #12
I built a 42" bucket for my boom mower, so does that count? I used the boom mower to load a rather large pile of dirt/sand onto my "Ugly Trailer" and hauled it 3/10 mile to my house with my JD. It was built in a square fashion, as I hoped if it didn't work out right, to be able to reuse the metal in a scoop to pull behind the tractor. Since it worked so well, I decided to leave it alone.
David from jax
CULVERTS / PIPE STAND (A68842)
CULVERTS / PIPE...
BAKER H PUMP ON SKID WITH ELECTROSPEED POWERSOURCE (A67714)
BAKER H PUMP ON...
PORTA POTTY (A68842)
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2006 TANKCON FRP INC. 130BBL FIBERGLASS ACID TRAILER (A67714)
2006 TANKCON FRP...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
