Dixie Chopper Question
/ Dixie Chopper Question #1
MtdMudBug
Omaha, NE
Ford Golden Jubilee
There is a an old Dixie Chopper listed locally without a motor offered for well under $100. The owner says it is complete except the motor, but I have not been to see it yet. Your thoughts on whether it is worth the time to put a new engine on?
/ Dixie Chopper Question #2
I would definitely buy it.
I used Dixie Chopper for about 20 years, and I still have three of them. Two 60 in, and a 42 in.
I have replaced motors several times.
The 25 HP vertical Kohler is a good engine, and easy to install.
Honda.
http://www.northerntool.com/shop/tools/product_200510826_200510826
Depends on the pulley hub as to the engine shaft size.
You can probably get a new 25 for about $1200, maybe less.
You should be able to work on just about everything on the Chopper .
Dixie Chopper Parts - OEM Parts
Dixie Chopper Parts
Thanks J.J. I am too often too much of an optimist when it comes to these things and I am just worried it is missing important stuff. I would not credit the current owner knows much about it and I don't need another big project, but if this could be repowered I thought for that small amount of dough this would be a good (hopefully minor) project. I've re-powered some other stuff and it has so far been relatively simple, but I don't know how long this has been sitting and how well it was preserved.
One general question - does a replacement engine require a generator/alternator? I know on some other units they utilize an electric clutch and you gotta have some juice to operate.
Thanks guys!
/ Dixie Chopper Question #4
Dixie Choppers run from $5000 to $12,000
My 42 has an electric clutch.
The 60 in Chopper clutch is manual lever.
You could look at the parts manual for that model Chopper and determine what is missing.
Yes, you need voltage.
Most engines have an alternator to charge the battery.
The carb probably has a solenoid on it.
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2012 PROCO 130BBL (A65643)
2012 PROCO 130BBL...
2015 Volvo 85160 4yd. Loader Bucket Attachment (A64553)
2015 Volvo 85160...
2019 KENWORTH T370 FLATBED TRUCK (A65643)
2019 KENWORTH T370...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
