Lineman North Florida
Veteran Member
- Joined
- May 12, 2008
- Messages
- 2,070
- Location
- LaCrosse Florida
- Tractor
- Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
I have gutters on the front of my house, but the lay of the land slopes downhill towards my house which has a block stem wall foundation and I have always heard you should try to keep water away from your foundation, so what I was thinking of doing was to dig a trench about 2' wide and say 4' deep all the way across the front of the house and fill it with gravel, my question is will this work? second would landscape weed block serve as a good enough barrier to keep the 1' of topsoil from filtering into the gravel as I would want to plant grass over the gravel so it was'nt such an eyesore, I should also mention that the soil usually will soak up the water from an average rain but on a couple of occasions we have got as much as 4" of rain in an hour and this is when the water seems to not have anywhere to go, any suggestions? Thanks in advance for any info.
