Diverter valve - spool type question
/ Diverter valve - spool type question #1
dstig1
Super Member
W Wisc
Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
I am upgrading my tractor and will need to do a 3rd function again. I'm trying to source the components at lower prices now that I know what I'm looking for (mostly), which leads me to my question. The Bosch valve on my old tractor uses the "6B" spool type from the drawing below where the work ports are open to the input ports during the transition from position 1 to 2 (brief as it is). It looks like they would have to special order that, but can get the "6A" style from stock. 6A is closed at the transition point. I doubt it will matter either way, but I figured I could ask here and get confirmation or pointed another direction. Thoughts/concerns/ideas?
/ Diverter valve - spool type question #2
Dave:
The "6B" selector valves have an overlap so that if you shift while pressurized fluid is flowing into the SV and out a work port (you are extending a cylinder) there is at every moment during the transition a place for the pressurised fluid to go (i.e., to extend the cylinder in the other circuit). This avoids a sudden stoppage of the pressurized flow and the resultant pressure spike. It is just like the water hammer in home plumbing when the faucet is suddenly closed at the end of long piping; the kinetic energy of the moving fluid creates a pressure spike much higher than the normal system pressure. This pressure spike may ultimately trigger the system relief valve, but only after it reverberates off the closed selector valve and travels back to the relief; in the meantime the pressure spike can damage hoses, etc.
The disadvantage to selector valves with overlap is that if you are using the valve to actually hold the cylinder extended after the work ports are shifted to the other cylinder, there will be pressure from the extended cylinder that may overcome the pressure (if any) in the other work port while they are connected, which would allow the extended cylinder to fall a bit and force fluid out the other work port. As a practical matter, selector valves usually have too much leakage even when closed to hold a load in position for very long.
So the "6A" selector valve with no overlap should work fine if you remember to shift it only when no fluid is flowing from the pump port through a work port. If the SV is in its typical location downstream from a directional control valve, then the DCV should be in neutral, so that no fluid is flowing to or from the SV, when the SV is shifted.
Thanks for a very thorough explanation. Based on this, I think I should stick with the 6B style. Since this is a button on my loader joystick, it is very easy to hit it a bit early or late when trying to clamp/open the grapple. If the risk of pressure spikes is that significant, I should aim to avoid that problem by going to the B valve.
Thanks!
ALUMINUM STATIONARY LOUVER (A64281)
ALUMINUM...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
