Ditch Witch
/ Ditch Witch #1
Dwellonroof
Batavia, Ohio
John Deere 3046r
I'm thinking about buying a ditch witch with trencher and backhoe combo it's probably an older model 3610dd I don't know the year but he guy said it is under 1000 hours.
Any thoughts on these ?
What to look for prier to purchase ?
It is a diesel 3 cylinder he said so is it air cooled or water?
Thanks in advance.
/ Ditch Witch #2
Thanks in advance.
Great machine...I have the model (3610) where the back hoe station is centered rather than offset on the right side...
only issue is visibility using the 6 way blade...
Equipment Specifications for a Ditch Witch 3610
/ Ditch Witch #3
Was watching Andrew Camarata's youtube channel yesterday and he bought an older Ditchwitch but with a rock wheel. Had several glitches he had to fix and a short learning curve before he was able to get a job done with it.
/ Ditch Witch
I;m now looking at a RT40 it looks newer maybe 2005 year with 950 hrs. the other one the owner didn't text me the serial number so I'm not interested.
/ Ditch Witch #5
I too watched Andrew with his rock wheel. I'm not sure it's wise to own such used equipment. He made repairs. First job, machine broke down. Believe me, I'v been there. You can make a living with a couple of pieces of newish equipment. Why burdon oneself with dozens of old relics?
Gotta love the Creeper gears in those Ditch Witches. I miss that on a tractor I used to have. Get off the machine and let the machine do it's thing. Adjust the steering once in a while.
/ Ditch Witch
I purchased the RT40 now waiting on delivery hopefully one day next week.
/ Ditch Witch #7
It hard to see from the pic but it looks like it might also have the additional valve set that lets you work the 6 way blade and move the machine both forward and backward from the back hoe station...(in mobile drive)...these machines have two drive methods...gear and hydro...!
/ Ditch Witch
Yes it does and also the drilling tool and 100' of rod.
I used it at my oldest sons house to put in 90' of sump pump line and it did great but only needed to trench 2' deep, Soon I'll be off to my youngest sons place to install 1200' of water line in Mt. Olivet, Kentucky.
/ Ditch Witch
Started the project and ran into rock big rock so had to quit trenching and use the hoe. After about 200’ sprang a hydraulic leak as line rubbed on motor mount , ordered new hose $75 shipped and off to install. Installed hose and back at it but had flat tire which only needed new inner tube.
/ Ditch Witch #10
That rock doesn’t look that bad and you’ve got a rock chain to boot. I’ve ditched through worse with a similar trencher. Mine doesn’t have a backhoe but it kinda needs one for digging the end of the line out. Does the backhoe on these work pretty good or is it more clumsy than useful?
/ Ditch Witch
The backhoe works really well as far as the rock chain the bits keep coming out and at a creeping pace the engine will stall because of jamming,some of the rock are very large limestone and hard. Maybe I should go slower and maybe saw through the rock I’m not sure.
/ Ditch Witch
Finally got the water installed except for completing the backfill since I blew a hose on the blade which was my fault because I seen it was a rub problem prior but forgot about it.
I did have about 100’ where I could trench really well but besides that I had to use the backhoe.
/ Ditch Witch #14
That’s a mess. I hope you’re taking precautions to not bust the line with that much rock. When I’m dealing with one that bad I usually put different dirt in the bottom and a little bit over the pipe. If it was a short run I might put the line in conduit but I’d hate to buy 1600 foot of it. IMG_8975.JPG
/ Ditch Witch
I'm looking for a smaller bucket to put on the Ditch Witch, say 12" or maybe 9" would I have to purchase a Ditch Witch bucket or are there universal buckets that would fit ?
/ Ditch Witch #16
Might be. Measure pin size and spacing (width and separation) and look around for something that matches.
Aaron Z
2006 Chevrolet TrailBlazer SUV (A64557)
2006 Chevrolet...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
2014 FREIGHTLINER CASCADIA 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
