Ditch and Bank Mowers -- Too Fragile for Regular Use?
   / Ditch and Bank Mowers -- Too Fragile for Regular Use?
If you had a new shaft made with it longer where its welded maybe 1/2 an inch you could plate the backside and make it stronger. But it might break somewhere else..
Yes, I've been thinking having it longer so it protrudes through the hole a bit might be good. I'm surprised it wasn't made that way. It was just welded on the back side, flush with the back of the plate. I need to be sure there's room there for it to come through.
   / Ditch and Bank Mowers -- Too Fragile for Regular Use? #12
I have a Maschio Giraffa since 2017. I use it to mow around ponds , down roads , and some times general mowing. I have never damaged this unit. I have bent my lift arms on my tractor when I was not watching what I was doing but the mower is in perfect shape.
   / Ditch and Bank Mowers -- Too Fragile for Regular Use? #13
I have a rotary ditchbank cutter that I wouldn't even consider doing straight line mowing with for the very reason you posted this thread. Mine is super heavy and if you aren't careful it will flip a tractor in a heartbeat. I just don't think these types of cutters are made for that use. But then you wouldn't catch me doing any type of 3PH work with a stupid loader hanging on the front of my tractor either. But that's just me.
   / Ditch and Bank Mowers -- Too Fragile for Regular Use? #14
I’ve been mowing with the loader attached for over 30 years and wouldn’t go through the hassle of removing it to mow. If I did that, I’d have to attach/detach the loader 30-40 times per year! Lol. I find it to be really handy for knocking tree limbs down, pushing fallen trees out of the way. Sure beats having the cab damaged. I even use it to stabilize the tractor on steep angles. The bucket can also be used to carry chains or other extra tools.
On new customer fields, the bucket can be lowered and curled upwards to a few inches above the ground to feel for stumps, rocks, etc.
   / Ditch and Bank Mowers -- Too Fragile for Regular Use? #15
I can see that. I don't mow anything that has any surprises in it so that's a non-issue for me. I just find it cumbersome to maneuver with. I put mine on or take it off 4 to 5 times a week at times. I can put it on or take it off in 5 minutes. Mine is easy and fast.
   / Ditch and Bank Mowers -- Too Fragile for Regular Use? #16
I mow regularly with a ditch bank flail and have not had any issues yet. However, there is no doubt a heavy duty rotary mower is more robust and is less maintenance. I do enjoy mowing with my flail though.
I do have a question for Terry. Do you have a float option for your rear remotes and do you mow with that cylinder in float? I could see where that kind of damage could happen over time if it can not float to follow the ground.
   / Ditch and Bank Mowers -- Too Fragile for Regular Use? #17
So is mine, but 5 minutes (mine would be more like 10) x 50 times off & on would be 500 minutes of time or about 8-9 hours.
Plus the risk of damaging the fittings, a line, etc.
I actually look at having the loader attached to tractor as a plus, a protection, a convenience.
   / Ditch and Bank Mowers -- Too Fragile for Regular Use? #18
Loaders aren't stupid, operators are. I admit mine gets in the way but I always remove the bucket which is always the issue. Being old, my depth perception is sometimes off and with the bucket on, I tend to run into things expensive.
   / Ditch and Bank Mowers -- Too Fragile for Regular Use? #19
I mow three acres of field, mostly steep with lots of trees, and half a mile of road side twice a year. This broke while mowing in the field.
How many hours of use on this flail--maybe 30?
Machine shop or welding shop depending on who can do the work needed.
   / Ditch and Bank Mowers -- Too Fragile for Regular Use? #20
I guess I grew up running tractors before loaders were a thing. To this day a tractor to me still feels awkward with a loader on it. I use it when I need it which is quite a bit but when I don't need it I don't want it on my tractor.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF FISHING GEAR (A58374)
PALLET OF FISHING...
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
TAYLOR PITTSBURG SPIN SPREADER (A58374)
TAYLOR PITTSBURG...
3PT SCOOP PAN (A52708)
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
