Disking Questions
/ Disking Questions #1
Jerome
Elmvale Ontario Canada
Kubota L245dt
Can I use a disk in reverse? this would be ideal to get close to the edge of the feild where there is a slight drop off and a danger of tipping. I saw in another post the damage of having the disk down when turning how tight of a turn can you do with the disk in the ground?
/ Disking Questions #2
If your disc is a pull type, then sure, it'll go in reverse. If your disc is a 3 pt type, there is risk of bending a 3 pt lifting arm or bending a toplink, especially if you hit something.
Which type is yours?
/ Disking Questions #4
IMO don't turn a 3pt in the ground. I loaned mine out and this is what happened with someone that didn't know any better.
/ Disking Questions #5
backing up on level ground? yes.
turning more than just slightly? no.
/ Disking Questions #6
You can only make gentle sweeping curves, not turns, when disk is ground engaged. You can lift disk with 3pt, back up to something, drop disk and pull straight forward.. do this several times... it will break up ground better than nothing...
however, I question why you want to get so close to a slope/tip point... erosion might be a problem if you do... you are best judge of this, but I stay away from breaking up ground already in grass at such points. Of course, if there is no grass there now, then disking and planting grass can be a good thing...
/ Disking Questions
Lee it is your post that made me ask the question about turns lessoned learned.
Texas John after many years of plowing by the previous owner there is a ridge along the ditch on the windward side of the driveway that catches the snow in the winter, I want to loosen this up so that I can level it out so I can mow the ditch and not have so many drifts in the winter. I can get two foot drifts on a sunny day with a wind.
Thanks for all the help
/ Disking Questions #8
brr...2ft drifts... brr.... I'd want to do something about that, too... maybe that's why I live in Texas:eek: Best wishes on leveling that out!
/ Disking Questions #10
http://img.photobucket.com/albums/v499/leeinmemphis/disc1.jpg[/IG][/QUOTE]
Lee did you ever get your disc trued back up? I saw the post on tndeer but never saw a results post.
2020 Case TV370B (A64126)
2020 Case TV370B...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
OIL TANK W/ LINCOLN PNEUMATIC PUMP (A64277)
OIL TANK W/...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
