Disk Size for a Kubota MX5100?
   / Disk Size for a Kubota MX5100? #21
I had a 14 foot "Big Blue" disc by Burch (24" diameter blades x 1/4" thick x 9" spacing) back when I farmed and pulled it with a Ford 9000 (120 HP)with dual rear wheels. It was all that tractor wanted when wheels were up. It have 4 each 11:00 x 16" transport tires that we filled with water for extra weight. I like the pull type rather than 3 PH for better cutting, easier to hitch up too. They do seem to pull harder than the same size 3 PH style although I have an 8 foot 3 PH style similar to the one EA posted. In wet conditions I will sometimes have to raise it up to pull it thru even with my 70HP in 4 wd with loaded tires. I have pulled it in dry conditions (dirt hard as concrete) with my 45 HP Yanmar but it did spin the wheels a lot after about 3 passes when it got down to axle cutting depth.
I would hazard a guess that you may be able to pull an 8 foot disc with your tractor given the right conditions. If going gets tough, just raise the lift to carry some of the weight. I don't think I would try for a pull type without wheels unless you want to be getting stuck a lot.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2019 CHEVY 5500 CAB CHASSIS (A50505)
2019 CHEVY 5500...
CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
CATERPILLAR D3K2...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
JLG 1255 Telehandler (A52128)
JLG 1255...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
