disk harrow: spacing between front gangs
/ disk harrow: spacing between front gangs #1
FrankT
Should there be a space between the internal bumper washers
on the left and right gangs of harrows when the gangs are set at maximum angle? If so, what should be the minimum space? 5 disks per gang
/ disk harrow: spacing between front gangs #2
Not getting the 'picture' regards your question. Maybe just a terminology thing, but a photo or downloaded picture of the disk you are asking about might help.
I think the answer is 'yes', but that isn't very definite.
Do you think the disk is broken, mfg. wrong, or just not the way you would like (or think) it to be?
/ disk harrow: spacing between front gangs #3
The old good disks had large, large metal washer-bumper-hubs on the first blade & rubbed against each other on this.
The elcheapo tiny 3pt disks from the farm supply store probably don't. Harder on the bearings. Depends on your brand?
--->Paul
had to remove gang in order to replace worn out axle, bumper washer and broken disk. I forgot the spacing (i.e. touching or not) between bumper washers on front gangs
el cheapo...INTERNATIONAL is brand...think it was made in India....normal size disk...actually heavier duty than bush hog brand I use
but do need advice on whether bumper wahers should touch...seems like it cause premature wear
/ disk harrow: spacing between front gangs #6
I believe that on every disk I ever saw the bumper washers on the front gangs were touching.
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
LOOK! (A63111)
LOOK! (A63111)
1999 Playbuoy Pontoon and Boat Trailer (A62613)
1999 Playbuoy...
2007 International 8600 Parts Truck (A63689)
2007 International...
