DiscountHydraulicHose.com
/ DiscountHydraulicHose.com #21
Aaron, I did the same paperchase, found Hydraulax etc, and why on one zoom level that other name popped up. Can't make this stuff up...?
I'm delighted these guys are close to me, and mail order makes sense, this is not the best part of Philly. If you look at their building on close up, you
can see they've been there a long time.
red herring, that's all. Drew
I'll order my splitter hoses from them and give a full report...:cool: ok, a full report for a nice advertiser.
/ DiscountHydraulicHose.com #22
Ken, thanks for the info on matching hose/fitting - although I did mention that in my post.
As to the help on assembly - it would have been nice if that info was to be found on your website (or maybe more obvious) - instead, I finally found a U-tube vid on a different manufacturer's similar connectors and went from there. Did it just the way you described here.
On a more positive note, the above is my ONLY minor complaint on your site (and NO complaints on anything else) - you're my "go to" choice for fittings. Now, if you could add control valves to your line :licking: ... Steve
Steve, it's on my "to do" list. :)
It's a long list, though, so I can't promise when it will get done. Among other projects, I have a number of helpful resources/tips that I will be putting together and adding to our web site for reference.
/ DiscountHydraulicHose.com #24
The hose I ordered came yesterday. Quality looks fine but I have one question-where's my invoice?
Jim,
The invoice should be in the box with your order. If it wasn't, you can print a copy of your invoice by viewing your order history online at DiscountHydraulicHose.com. All you have to do is log into your account and click "My Account/Order Status" in the upper right hand corner of any page on our site.
If you have any problems with that, message me privately with your order number and I will email you a copy of your order confirmation, which contains a complete invoice.
/ DiscountHydraulicHose.com #26
I need some nylon protective sleeve for two 3/8'' hoses. What size should I get?
Hose ID is not a factor when buying protective sleeve. Getting the sleeve to fit over the OD (and maybe the fittings) is all that matters.
Measure the OD and add a little (maybe 1/8") to give the sleeve room. If the hose is long, you don't want the sleeve so tight that you can't pull it over the length of the hose. If you have to pull the sleeve over fittings that are already attached, consider them as well. Measure at the widest point and work from there.
/ DiscountHydraulicHose.com #28
Hi KEN,
If you have the time, can you give us a comparison of fitting and hose size after a hose is squeezed onto a fitting, or any fitting with out a hose.
For example, what is the inside diameter of a 3/4 in fitting?
---------------------------------------------------- 1/2
-----------------------------------------------------3/8
Is a 1/2 in QD inside diameter really 1/2 in?
Looking at this hose velocity/hose size/GPM chart, can one derive the flow through a particular size fitting or hose?
https://www.google.com/url?sa=t&rct...=4gu5qj1C2wFW2uLHya121A&bvm=bv.49967636,d.aWM
/ DiscountHydraulicHose.com #29
What I am really asking is, can I insert a 1/2 in rod inside a 1/2 QD or fitting or hose.
What is the real inside diameter?
I am not sure it is a big deal unless you go way outside of the envelope.
It may affect overall cost if you deviate from accepted standards.
/ DiscountHydraulicHose.com #30
JJ, I have several of DHH's 1/2" QD's for a few projects - the female (by "1/2", I mean 1/2 NPTF) check ball seat is almost exactly 3/8" - the male looks to be a little bit smaller than that. These are the standard "AG" versions.
In my case, it's no biggie - using 3/8 hose, older tractors, lucky to put out 6-7 gpm @ 2200 psi.
If I were doing this for a higher volume application, I would go bigger. I don't remember seeing ANY QD's that didn't restrict flows (haven't messed with higher volume stuff like skid steers, only my case backhoe which has about 22 gpm - for projects on that animal, I'll be looking MUCH larger, and/or NO QD's... Steve
/ DiscountHydraulicHose.com #31
Years ago, I picked up a fudge factor in using QD's, and that is to go up one size.
For example, if using 3/8 in hose, then use 1/2 in QD's.
Here is some data that might be useful.
Hydraulic Warehouse - Size Chart
/ DiscountHydraulicHose.com #32
Yeah, that's what I'm doing - my two smaller tractors are getting 3/8 hose, 1/2" QD's on remotes and other mods - the BH uses 3/4" hose most places, the tank return is at least 1", and the QD's to bypass the hoe are at least 1-1/4 (the actual sleeves are nearly 2")
I'm thinkin' that when I get to ordering fittings for the hoe projects, I'm gonna need a co-signer :eek: Steve
/ DiscountHydraulicHose.com #33
No way around it. QD's restrict flow. Just the nature of the beast
/ DiscountHydraulicHose.com #34
That is why you use one size larger QD.
It would be easy enough to test.
Connect a full set of QD to a hose and place in a 5 gal bucket and measure the flow,
Then remove the QD and place the hose in a bucket and measure the flow.
I don't believe you will see a big difference.
/ DiscountHydraulicHose.com #35
Ken, I've had no luck either online or on the phone getting this info, hopefully you can help -
I ordered and received 3 different sizes of "convert-a-flare" tube fittings, specifically 3/8, 1/2" and 3/4" - it's finally time for these to get installed, but to date I've found NO HELP WHATEVER on install directions - things like positioning of the tubing in the 419 sleeve, # of turns past finger tight, using a fitting instead of the million-dollar tool, etc -
I'll be using the fitting to set these, in case it wasn't obvious :rolleyes:
I REALLY need to get on with this, please advise. On one of the sizes, I only bought a couple spares, so it's not like I can go "trial and error" here.
Thanks in advance for ANY help you can give... Steve
/ DiscountHydraulicHose.com #37
Do you stock hyd dust caps and plugs for QD's.
/ DiscountHydraulicHose.com #39
Wow just ordered 2 -16 foot hoses with all the fittings and QDs it was 75% cheaper than my local auto parts store and got them in just 2 days.
Will definitely order again. your online catalog is great.:cool2:
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
2016 MACK CXU613 SLEEPER (A67714)
2016 MACK CXU613...
Gehl RS6-34 (A64119)
UNKOWN NATURAL GAS GENERATIR (A67714)
UNKOWN NATURAL GAS...
2008 THE MACHINE CO. THAWZALL H250 HEATER (INOPERABLE) (A68842)
2008 THE MACHINE...
2015 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2015 CHEVROLET...
