Disc vs Sickle Bar
/ Disc vs Sickle Bar #1
cowpie1
Kellogg, IA
NH TC33DA
I have no experience with the "disc" type mowers out there, but they seem to be a lot of them. Could anyone tell me what the difference is in cut or use of disc mowers compared to sickle bar mowers.
Best I can tell from the little info I have come across is that the disc type are heavier and cost more but from what I have seen when I have seen one mowing is nothing spectacular compared to sickle bar mower.
Would appreciate some of your experiences comparing these types.
Cliff
Cliff
/ Disc vs Sickle Bar #3
Do you have anthills in your field? I hear they are murder on sickle bar mowers...
David from jax
/ Disc vs Sickle Bar #4
David from jax
No anthills. Just basic pasture and hay ground mowing. Just interested in the differences between the two types and what makes disc mowers so popular compared to sickle bar.
I do trim up hillside terraces and road ditches.
Cliff
Cliff
/ Disc vs Sickle Bar #11
Sickle mowers have a bar with teeth on it that goes back and forth, just like a beard trimmer on an electric razor. It is a very old design with many drawbacks. Rocks, tree branches, fence posts and other "hidden" objects are very hard on the cutters. When you cut the hay, it leaves it at the cut length, laying where it was cut. If you plan on baling the grass/hay, is will still need to be raked and conditioned. The initial cost, and repair costs are lower than disc cutters. Disc cutters are much like a lawn mower. If you are refering to farm disc cutters, they will condition and windrow the grass/hay too. If you are refering to mowing type disc cutters, there are various grass discharge options. Some of the more modern farm discbines for cutting hay allows you to run really high ground speeds, upwards of 10mph!!!
Without knowing what specific mowers you are comparing, I can't give details but that is a basic overview.
/ Disc vs Sickle Bar #12
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2005 JLG G6-42A Telehandler (A62613)
2005 JLG G6-42A...
2015 John Deere 6130D (A64126)
2015 John Deere...
Stout Brush Grapple XHD84-6 (A66285)
Stout Brush...
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
