disc harrow
/ disc harrow #1
osceolaman
Have a new 50hp Kubota 4wd. Want a disc harrow for a few 1 acre food plots. Will by used. Any suggestions on width, weight and price. Someone told me should not be wider than wheelbase of tractor. Sounds silly. Was thinking 800-1200 could by a quality used disc harrow. Suggestion?
/ disc harrow #2
With 50 hp and 4wd I would look at a 8 to 10 foot disc. Do you have remote hydraulics? You should be able to find a good disc for that price. watch the local farm auctions. I use to pull a 10 foot disc with our 45 hp two wheel drive. Your 50hp should do a great job.
/ disc harrow #3
50 HP 4WD should handle an 8 footer with next to no effort. 10 feet isn't out of the question. Are you interested in a wheel disc or 3-point?
$800 to $1200 should put you in range for a GOOD 8 foot disc.
The drawn (wheel disc) is a better choice especially if you won't be moving it from place to place. 3-point models are easier to transport (read, load on a trailer) 3-point models generally don't work soil as deep without loading extra weight. (wheel disc's usually have more built-in weight)
/ disc harrow #4
If you plan on using your disc near any trees etc. buy a 6ft
and save yourself some trouble.
/ disc harrow #6
I'd say from the neame he's from Florida, South most likely... /forums/images/graemlins/grin.gif
The reason to keep it inside the wheels is to make sure you can get the hares where you want to go. Assuming the tractor can get there. Since youre doing food plots I would think this to be pretty important..
/ disc harrow #7
osceolaman, for a 50 hp tractor and I'll assume a L or M either can handle a 10ft or less disc if you have rear remotes a wheeled disc would be nice but expensive when new plus with a 3pt you can easily pick it up and drive to the next and it follows no matter what so in small plots where backing up is necessary a 3pt is simple where a pull type may not be. I'm running a 90hp but my intentions were the same food plots not farming. I ended up getting a 3pt Hay King 8' disc and I weighted it down with 640lb of water in two propane cylinders it works well for me BUT I was not content with the tillage after the first season so I bought a 8' Hay King 7shank chisel plow to work the soil better and deeper and then I go back and disc up the seed bed and plant. It works well except no matter what you do you still will be relying on the man upstairs for water unless you plan on watering them as well. In 8 months we've gotten 2-1/2" of rain I can't even get rye to come up as I replanted halfway thru deer season when my wheat and oats withered and died. Good luck on your plots and pray for rain I'm convinced that with rain you can do it. Many of the TBN'rs will tell you that you don't need a plow for food plots it don't need to be pretty and your not striving for 90+% germination but I went that way to try and retain more moisture in the soil when/if it rains. My first planting came up fine without it but shortly after it came up we went into a drought and it hasn't rained since. Welcome to TBN there is a wealth of information on the site from accumullated 100's of years of experience, you'll find many ways of skinning the same cat most of them will work for the region that your in so fill out your bio and local folks will be able to help you best I'm in South Central Texas and pray for rain the folks in Oregon probably pray it'll stop and if your planting in 6' of top soil instead of my 6" you'll have great success with about anything you can pull to rough up the seed bed, heck before we got the tractor I was doing it with a recently cut cedar tree tied to the back of a 500hp Jeep.
Steve
/ disc harrow #9
</font><font color="blue" class="small">( I'd say from the neame he's from Florida, South most likely... /forums/images/graemlins/grin.gif )</font>
OsceolA = Fla.
Osceol = Wisc.
One extreme or the other----------------!
/ disc harrow #10
I'm very happy with the Athens Plow 55 disc harrow. This was recommended by my Kubota dealer for use with my M4800SU (50 hp). It is a very heavy piece of equipment that does a nice job with no extra weight added. I'm using to maintain approximate 10 or so acres of openings from 0.5 to 1.5 acres in size. Soils are sandy so one pass is all that is required.
http://www.binkleyhurst.com/Sales/Small%20Farmer/compact_discs.htm
/ disc harrow
Thanks for info. The land of the osceola turkey is correct, dry, wet, dry wet a pain probabley like South Tex.
No remote hydraulics. Checked with local dealers. But after shipping etc. Almost worth ordering from the NorthernTool website. Which I found by mistake. Could travel, spend gas, look at used, call, travel by that time a new sounds affordable.
Probabley go with a 6ft-7 ft.
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
UNUSED FUTURE CAT 303-46" EXCAVATOR RAKE (A65055)
UNUSED FUTURE CAT...
2014 CATERPILLAR 924K WHEEL LOADER (A65053)
2014 CATERPILLAR...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
