Disc Harrow
/ Disc Harrow #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I am fixing a disc harrow for a friend, one of the axle needs to be replaced. Now the old axle is round but aggrisupply only carries square axles. Are the round axles thing of the past or something? I am confident I can make it work, just curious.
/ Disc Harrow
Seems like there is only one company that still makes round axles. But I am in luck, this harrow is already using all elements with square hole, I guess round axle can be used with square holes, without problems.
Here, if you ever need round axle, email from aggrysupply:
Only one i know has round axles is Shoup mfg. company in illinois, their phone number is 1-800-627-6137.
/ Disc Harrow #3
Are you referring to the gang bolt? If so there is a plethora of round gang bolt discs, it is not uncommon at all and are still used today. Ultimately the goal is to keep everything tight so it spins as a unit and not on the gang bolt (among other reasons). If you accomplish that then problem solved.
/ Disc Harrow
I guess i do :)
The old one was bent, it has to be replaced.
John Deere 5090GN (A60462)
John Deere 5090GN...
2022 EZ-GO ELITE...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
2006 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2006 Montone...
