Disc Harrow
/ Disc Harrow #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I am fixing a disc harrow for a friend, one of the axle needs to be replaced. Now the old axle is round but aggrisupply only carries square axles. Are the round axles thing of the past or something? I am confident I can make it work, just curious.
/ Disc Harrow
Seems like there is only one company that still makes round axles. But I am in luck, this harrow is already using all elements with square hole, I guess round axle can be used with square holes, without problems.
Here, if you ever need round axle, email from aggrysupply:
Only one i know has round axles is Shoup mfg. company in illinois, their phone number is 1-800-627-6137.
/ Disc Harrow #3
Are you referring to the gang bolt? If so there is a plethora of round gang bolt discs, it is not uncommon at all and are still used today. Ultimately the goal is to keep everything tight so it spins as a unit and not on the gang bolt (among other reasons). If you accomplish that then problem solved.
/ Disc Harrow
I guess i do :)
The old one was bent, it has to be replaced.
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
17601CFL (A59228)
17601CFL (A59228)
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
2002 John Deere 544H Articulated Wheel Loader (A61572)
2002 John Deere...
