Disc harrow vs power tiller
   / Disc harrow vs power tiller #11
I used a subsoiler & 5' King Kutter tiller behind my old L3200 to redo my pasture/field. It was a bit slow, but good results. Some lumps parallel to where I tilled or ran a drag after seeding. Would be smarter about finishing it now, but would use the same implements.
A disc requires speed to properly mix & distribute dirt. A tiller doesn't. You can use the tiller later for small garden plots & other stuff a disc won't do.
   / Disc harrow vs power tiller #12
If you want to own a piece of a equipment rather than rent buy a landscape rake. You can break up the ground with the box blade then smooth things out with the landscape rake. Sometimes removing every other landscape rake time helps on compacted ground. I still suggest you use some type of leveling drag or hand rake for the final grade on a lawn.
On my landscape rake I removed every other time and put a 100lb suit case weight right over the pivot. It made a big difference and now dosnt act as much like a rear blade.
For grass tou really dont need more than a few Inches of loose seed bed. Theres no reason to disc or completely till the area.
   / Disc harrow vs power tiller #13
New house build and after it I have a 1.5 Acre site to sort out. I need to break up compacted ground for planting grass etc. Some of the compacted ground is bare earth I leveled recently with an excavator and some has rough grass on it I want to reseed. There are plenty rocks in the soil round here. I have a small tractor B2230 - 22HP and a box blade currently which I have used to do some of the final leveling of the soil I have moved around from big piles left over after the building work.
What is the best implement to break up the soild and leave a good tilled bed for planting? A power tiller (rototiller/rotavator/cultivator) looks good but I am concerned about it getting destroyed by rocks. I also considered a disk harrow - the tow behind type and also maybe a land rake. I can break up the ground using the box blade rippers, not ideal though. Ideally I'd also like to be able to get surface rocks collected easily after the soil is broken up.
Looking for economical options :)
Cheers
Rob
What type of soil was in your piles that you spread out? You said it was from excavating from the build site. In my area that means clay. Very hard pack clay after spring rains and dry summer. Terrible for grass to grow and takes years to break down into acceptable soil—still not good, it will just allow grass roots to penetrated.
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2013 Peterbilt 367 QMC 7060S 35 Ton Tri Axle Crane Truck (A55973)
2013 Peterbilt 367...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56436)
2022 Brush Wolf...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
