Disc harrow question??
/ Disc harrow question?? #1
drjay9051
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
Recently picked up a used Leinbach disc. I have a problem. It is hooked up to the three point and is level front to back and side to side. When I put the lift arms all the way down the disc seems to float along the ground and does not dig in deeply. However if I go in reverse the disc operates as it should, churns alot of earth. I do have the discs set to maximum angle.
The lift arms always seem to float, if I need to hook up equipment and the arms are full down I can lift them up manually. Is this normal? I suppose I can disc in reverse but two acres like that will give me a stiff neck. Should I put some sort of weight on the disc frame to keep it from following ground contour?
Jay
/ Disc harrow question?? #2
When you go in reverse you are lifting on the arms causing the back of the disk to dig in. I think you need to add some weight to the front gangs on your disk so they bite better.
/ Disc harrow question?? #3
I was always taught in my youth by my Dad to never ever backup a disc(wheeled version) and I would think that backing up a mounted disc would put all sorts of different strains on 3pt hitch arms and the bearings on the disc gangs. :eek:
/ Disc harrow question?? #4
Try changing the length of your top link. You can either raise the rear so the front will cut more or lower the rear to make the rear cut better. After playing with mine last summer I finally found a sweet spot where it cuts very well. I think it is just trial and error to find the correct length.
/ Disc harrow question?? #5
Jay
Shorten the top link so the disk is 2-3" lower in the front.
/ Disc harrow question?? #6
if it's level when in the fullly raised position then your toplink is set too far out, shorten it as stated above to be 3 inches or so lower in front than back
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2014 Ford Escape SE SUV (A61569)
2014 Ford Escape...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2014 KEYSTONE COUGAR CAMPER (A60736)
2014 KEYSTONE...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
