Disc Harrow Disc for 100hp tractor
/ Disc for 100hp tractor #21
I would say that's not the norm but is possible under perfect soil conditions, there is a reason you don't see farmers pulling offsets but see tandems all the time at least around here.
Those are the magic words. :thumbsup:
/ Disc for 100hp tractor #22
OK, I have looked at that option but don't I need to turn in the lime and fertilizer? It seems that if i just throw it on these slopes it will just end up in the creek.....
Need to soil test to find out no point in wasting money putting out something you don't need to.
/ Disc for 100hp tractor #23
Based on the info that you have given, if I were you, I would be looking at the 9 footers here.
Assuming that you don't want to waste time, I personally would not even consider anything under 2000lbs. But that's just me. ;)
Ditto what Brian stated. An "offset disk" with notched blades frt & rear is what I'd recommend. Notched disk handle grass & weeds better than smooth disk.
Soil test was the first thing I did. I had the Co-Op truck spread pulverized lime on the fields it could access. I bought a pallet of pelletized lime to carry to the sites it could not.
Why is an offset disc more aggressive than an in-line?
/ Disc for 100hp tractor #28
I agree with Brian on the offset disc but would choose the 8'4" model with 24" pans. That is about as much as your tractor can handle on sloped ground. A simple 3 point spike tooth harrow and or a cultipacker would help finish these plots off.
You could also use a 7' to 8' rotary tiller too. Good for mixing in amendments and leaves a good seedbed. A tandem disc harrow with large notched blades will work but will take more passes.
There are several ways to get this done.
/ Disc for 100hp tractor #29
I agree with Jeff a pull type harrow is going to be a headache trying to turn in a 2-4 acre spot. A 3 point type you can use the brakes to turn in your tracks in the length of the tractor.
I pulled trailer type disk all my farm life and with a 14 foot wide disk, I can turn it right back around and follow the path just disked up. It takes no more room to turn a pull type disk than a 3 PH type. When you have 10 feet or more disk on a 3 PH sticking out behind you, you have to allow for that as part of your turning radius= tractor length + length of disk so 10' of disk and 15'+ on tractor length is 25' or more whereas with a trailer type disk, you have the tractor + not more than half the width of the disk so a tractor of 15' in length +14' disk would only require turning radius of 22' using brake assisted turning.
I would look at a trailer type tandem disk that will pull much easier than an offset type but maybe not cut as deep but you really don't need 10" deep disking for a deer food plot.
Thanks for this. I will go take a look at it. I am kind of feeling this is the most appropriate implement for me. Simple, no hydraulics, small/narrow enough to maneuver logging roads. I understand it may take a few more passes than a more aggressive offset unit but we are only talking a maximum of ten acres combined here.
I see larger tow-type units with equal amounts or rust for less money on CL. is this guy high on this price?
/ Disc for 100hp tractor #31
Have you invested any time researching this TX4 Disc Harrow? Research whether Cat 1/Cat 2 hitch? Did you research the weight? Research the pan diameters? Did you research the Tufline brand?
The previous thirty posts provide comprehensive alternatives. You should demonstrate you have learned and can apply the information provided. You should not be sponging now.
Monroe Tufline is The Best in Disc Harrows. The lightest model in the 9'-6" TX4 series is 66 pounds per disc.
I am out of here.
I have read everything on it I can find online. Apparently it is actually model T4X, the seller has it listed wrong. I cannot tell from his pics or description what diameter the disc are or class the hitch.
I am even waiting on a quote on a new one.
As I said I am going to look at it in person to make absolutely sure of the specs and condition.
I was hoping I could keep sponging for a while longer though.....
/ Disc for 100hp tractor #33
Another vote for no-till. In a food plot setting just get a 7-10 foot drill and be done. It'll plant corn, beans, grasses, clovers, sunflowers and what ever else you need it to. Most drills have multiple hoppers so you might seed as much as 3 different seeds and rates and seed sizes in 1 pass.
As far as fertilizer and lime. Spread it on top and it'll work its way in. Is it the best no but it has advantages also. Just watch the weather and spread it before a light rain not a flash flood. It'll get in the ground before it washes down hill.
/ Disc for 100hp tractor #35
I guess you got it or someone beat you to it, it was deleted.
Ronnie
/ Disc for 100hp tractor #36
My neighbor had a guy disc his old hay field to try to turn it into a deer feed plot. The sod hadn't been broken in years. They pulled a disc over it several times but it just made a mess of piled up sod strips everywhere. He wanted me to mow it the next year and there was no way, it was way too rough. I think they ended up plowing it all under eventually. Lots of guys use rotary tillers for food plots around here but I don't know what's best.
Kevin
/ Disc for 100hp tractor #37
Kevin
Hello Kevin,
Almost all of the land I work with is irrigated fields which haven't been turned over in twenty years or more. I use an S tine field cultivator first followed by a rotary tiller. The S tine cultivator is good for finding trash buried in the field such as wire rope and other things which would wreak havoc with the tiller. After two passes with the cultivator I can till up the fields with the rotary tiller and have a good seedbed in 90% of the cases.
For most owners of compact tractors with hydro transmissions a rotary tiller is the ideal tillage tool imo. Since the transmission isn't under load because the tiller is pushing the tractor forward you can then utilize all of the pto power for the tiller. That removes most of the hydro transmission losses that would be experienced with high draft loads. A common argument here would be that farmers use discs in most cases and rarely use a rototiller. That is true also but these same farmers are not using compact hydro tractors for field work either.
With a 100 hp tractor properly set up you can have several choices for tillage. Which choice is best depends on the soil conditions and what you need to achieve.
/ Disc for 100hp tractor #38
op, one point to mention is that you don't have a 100hp tractor. (flame suit on) Most of those discs are rated at DRAWBAR HP not FLYWHEEL HP IIRC. Big difference right there. Look at your pto numbers to get a better idea. In freshly plowed ground I could yank a 16' JD disc around and my 5083E wanted no more especially going uphill. We have mostly heavy clays with a thinner layer of topsoil. I often had to bump the discs out of the ground with the hydraulics. If you are not ballasted correctly you will pull a lot less also. I have filled rear, wheel weights, and suitcase weights.
Ronnie
Yeah, I went ahead an got it last night. I am VERY happy with it. I believe it was the best choice for what we are doing and our experience level.
We just hooked it up an hour ago and put it in the dirt with minimal adjustmet. It is highly effective and I am very pleased with the results.
I am really interested in these all-in-one seed drills but I am OK with doing it the hard way a couple times. I always like to learn the fundamentals first.
I already have a field cultivator that is kind of light and a really nice cultipacker so I believe I am good to go.
/ Disc for 100hp tractor #40
Get the ground worked up with the disc, you can rent a no-till from CO-OP & get your seeds/fertilizer as well.
Congrat's on the purchase.
Ronnie
2008 Yale GLP070VXE 6,500lb Propane Forklift (A61572)
2008 Yale...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
Fendt FT900 Front Fenders (A63117)
Fendt FT900 Front...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
Zero Turn Mower (A59231)
Zero Turn Mower...
Headsight Autopilot Kit for Claas (A63117)
Headsight...
