Disaster down below
/ Disaster down below
Getting the PT to Tazwell will the remedy of last resort. Right now the Green machine is located in a position that will require an almost 50 yd. drive to even get it to a trailer. Don said the broken piece could be welded right there enough to move the machine since the entire piece would be replaced anyway. I need to get a local welder out to look at it. I've also concidered removing the seat that drags on the oil cap, starting up and lifting the mower deck to let it's weight remove some of the strain on the lower coupling then use a broomstick etc. to slowly drive to an accessable area. Any thoughts?
/ Disaster down below #12
<font color="blue"> but certainly a close look and some thought is in order before applying heat </font>
That would be my main concern... cooking the machine while welding. With some proper shielding I think it could be done without removing any hoses, wires, etc... it looks pretty open in there. I would be worried about cooking the joint. Is this a conceren? Also, two pieces were mentioned. I thought the piece would be one, with the donut pressed inside of it already. Is it two pieces that have to be assmbled? I can't tell and don't have my machine in front of me.
/ Disaster down below #13
Rick:
For a temporary short move, I don't see trying to weld the heim end back together. (It looks cast, but may not be.) Better just a chunk of plate with a big hole in it could be welded to the stub and the bolt taken out and reinstalled through the hole. Then the temp rig would be discarded when it was cut free from the front box.
Any kind of ring that the bolt goes trough could also be welded to the stub. It's mostly in tension unless you're picking up something heavy.
/ Disaster down below #14
I'd agree with Charlie that welding anything on it without some very careful examination is asking for trouble. Steel has to be 3200 degrees to melt, and that will cook wiring and hydraulic hoses that aren't even that close as the heat conducts away through the metal. Also, keep in mind that gasoline vapors will explode and hydraulic oil will burn. Be very, very careful! (And make sure the welder has insurance to cover any mishap or worse.)
I'd suggest keeping this as simple as you possibly can. Could you strap some 4x4's underneath it to support it horizontally (but still allow it to turn slightly), and tow or drive it back to a better repair location? Or, open your tow port and put the obligatory hose on the hydrostatic drive pump, and hire a tow truck w/ a several hundred foot winch (or a friend with another tractor) to help you tow it up onto a trailer. (See my post from the winter about putting my no-cranking tractor on a dolly and hauling it to a local shop!)
Good luck!
Dave
/ Disaster down below #15
Rick_Taylor, nice occupation..... /forums/images/graemlins/smile.gif
/ Disaster down below #16
Rick,
I'm sorry to see that happen. It's the one thing on the tractor that is most difficult to service. I wish that it was bolted into place to facilitate replacement.
From your post, it sounds like PT was aware of some broken heim joints on earlier models, but made a change? It does appear to be a cast piece from your picture.
I wish we know who the manuf of this heim joint is. I wonder if the manuf had intended for it to receive the lateral loads that the PT puts on them vs a tension/compression force. (I assume so, but it would be nice to know the specs)
I assume the bigger PT models use a similiar joint, but just bigger (Charlie).
Rick, please keep us posted on all the details of the repair. This one concerns me. /forums/images/graemlins/frown.gif
Duane
/ Disaster down below #17
<font color="red">
</font>
Bigger and different, but I'm not sure of details since I haven't had mine apart. My understanding is that my 1845 has a removable bearing insert.
/ Disaster down below #18
Rick: Something maybe worth a try.
Start the engine and lift the deck, as you suggested and see if it moves the joint back together a bit. If not, jack the middle until it's close or touching. Then, pull the pins on one side steering cylinder and replace it with a piece of chain. Then when you start the engine and turn the wheel toward the remaining cylinder, it will pull the machine together. Then replace that one with chain and release the hydro to drag it around. (You could also drive straight forward or straight back) Maybe with some jacking and prying you can get it ponted in the right direction.
Keep us posted.
I finally got some good info from Terry this afternoon. The complete ball bushing WITH welded-on stem and flat mounting plate is on it's way. Terry said to cut the old one off flush with the rear plate with a torch. Also should pour some water into the cavity just foward to keep down any chance of any grass etc. from firing off. He said welding the new one on with a torch should keep the temp down to a relitively safe level. I now have several days to locate a 1 13/16" wrench to R&R the big bolt and nut.
He said he'd be happy to fix it for me if I was a little closer. Said he could do it in about 10 minutes. If this doesn't work he may still get the chance. I'll give him credit for really wanting to help my situation. Watch this space.
/ Disaster down below #20
what i see in the pic is a slight dark spot where it broke. if that is there, it's an old crack? all i would do to move it , jack it back in to place, get a welder with a portable welder and weld it. use a piece of metal to shield the hoses from heat.take nut off or get an other one when you get the new joint.
an welder (good) welder can do the job in the field.when a million dollar machine brakes they fix it there, rain or shine.
if they need to take it to the shop,at least they will have a better idea of how it should look,tacking it together you will not make a lot of heat,take your time, use a heat sink, or the the crayon to stop the heat. you will only be welding on half of it. your not that bad off /forums/images/graemlins/laugh.gif
JLG 1930ES ELECTRIC SCISSOR LIFT (A59823)
JLG 1930ES...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
2023 Chevrolet Tahoe FL SUV (A59231)
2023 Chevrolet...
2019 VERMEER LP573 XDT VACUUM TRAILER (A59823)
2019 VERMEER LP573...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
