Disassembling the MMM pto shaft
/ Disassembling the MMM pto shaft #1
morpheus
Cut Bank, Montana
Kioti
Greetings, I am trying to disassemble the universal joint on the MMM drive shaft. I have pushed one of the bearings through the yoke, but I am not able to remove the bearing cup. There just doesn't appear to be enough of the cup sticking out of the yoke. Is there a trick to get it out? I ordered half of the pto shaft for the mower today and Messicks had the best price, but it was still $289.00. Becareful with the removal and installation of MMM so you do not "mess up" the coupler. Morpheus
/ Disassembling the MMM pto shaft #2
push it through as far as it goes then grab it in a really good vice and start to fight, watch the roller....
sometime a good pair of vice grips will do the job. there is no easy way except to cut the uni cross out with a oxy and the just punch the caps out after all the rollers etc have fallen out. this is actually how i do unis if im just replacing the cross. doesn't look pretty when im doing it but when its all done you cant tell and its done in 5 minutes not half a hour.
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
More info coming soon. (A64557)
More info coming...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A64194)
2015 SkyJack SJ86T...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
