dipper arm cylinder
/ dipper arm cylinder #1
swnoel
New Hampshire
Kioti DK35
on my bh has done it again.
First time out since I had nut replaced on the end of the cylinder shaft.
First one stripped off.
This time the end of the shaft has snapped off.
Didn't back into anything , just happened working a loose stump out of the ground.
Question... doesn't the relief valve protect against this kind of damage?
Dealer said no!
/ dipper arm cylinder #3
I agree with Jerry. The dealer should check to see that the relief valve pressure is correct. Sounds to me like it's too high and not relieving in time to save the cylinder from damage. John
No I haven't checked the pressures.
I asked the dealer if the relief should keep this from happening....
He said it won't...
I find this hard to believe.
/ dipper arm cylinder #5
If it is not overpressure then maybe you could check that the cylinder end is exactly perpendicular to the cylinder, if not their maybe some flexing going on as the arm swings through its arc loosening the nut and eventually stripping it or if its tight enough (the nut) then you may get metal fatigue and eventually break something off. Am I babbling or could this be a possible cause?
Steve
/ dipper arm cylinder #6
</font><font color="blue" class="small">( No I haven't checked the pressures.
He said it won't...
I find this hard to believe. )</font>
Well, if that's the case, I suspect my loader would be in a shambles after what I've managed to do with it.
John
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
136" BULLDOZER ROOT RAKE (A65056)
136" BULLDOZER...
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
2017 Peterbilt 320 New Way 20ASL 20yd. Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
