Traction digs too well
/ digs too well
i'm running with a box scraper on the back and i go through the sand without a problem. the weight made all the difference.
/ digs too well #22
Sounds like you are on the right track to solve your issue. Very nice looking tractor by the way.
If you were to pull the FEL you will fine it would be awesome handling the box blade I expect but if you are using the box blade then the FEL may be handy at the same time. :)
Light duty after market FEL's seldom have a sub frame to the rear axles which often permits the design to move the weight of the FEL 12" or so towards the rear tires. Filled tires and rear wheel weights are two things most any tractor without a backhoe needs.
When you talk about getting suck in our clay you are talking about WATER but that is not your problem. We would call getting suck in sand getting 'hung' since there is no water involved. :) Wide as possible tires would be a plus in loose sand but not cost effective except at the time of purchase.
It will just take some practice and try to keep the nose pointing down as much as possible when working even if it means driving in loops to get to the high point.
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61307)
2017 Yale GLC050VX...
2018 HINO SA (A58214)
8ft. Fork Extensions (A59228)
8ft. Fork...
